LS2 Valve Spring Color
Old Jun 24, 2007 | 10:58 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default LS2 Valve Spring Color
I recently bought a set of heads for my LS1 conversion project. I was told the heads were off of an 04 Z06. The heads have 450 miles on them and are stock takeoffs from Mallet. I was wondering what color are the springs on the LS2 heads? The stripe painted on the springs on my heads almost look tan color.
Any help is appreciated.
Old Jun 24, 2007 | 05:03 PM
cbrf4i1's Avatar
cbrf4i1
my ls2 243 heads are yellow, not tan.
Old Jun 24, 2007 | 06:33 PM
Paulkr's Avatar
Paulkr
Default springs
My Ls2 has Yellow
Old Jun 25, 2007 | 09:11 AM
Michrider's Avatar
Michrider
The only difference between an LS2 and a LS6 head is the LS6 has lightweight hollow valves. So the only real way to verify it's an LS6 head is to weigh a valve and compare with a known LS2 valve.
The LS6 should have hollow intakes and Sodium filled exhaust valves.
Old Jun 25, 2007 | 10:05 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
could fade a bit but Yellow is what I saw on my 05.
Old Jun 25, 2007 | 11:39 AM
cbrf4i1's Avatar
cbrf4i1
that would be alot of fading for what was supposely only 450 miles.
Old Jun 25, 2007 | 01:59 PM
JFTaylor's Avatar
JFTaylor
St. Jude Donor '06
To LS2 Valve Spring Color
