It's time for brakes on my base suspension '05 coupe. I have always admired the look of the optional Z-51 cross drilled rotors and have been thinking of replacing my solid ones with the cross drilled strictly for asthetic purposes. This car is driven daily but very gently (no track days or racing). Can anyone here tell me difinitevley whether the cross drilled rotors will simply bolt on? Is there a difference in the caliper bracket in order to accomodate the larger rotors? Is this a silly change or an actual upgrade? 3 local Chevy dealers can only tell me that the calipers are the same but they don't know if the rotors are interchangable (imagine that). Any input or opinions will be greatky appreciated. I know that this is the REAL source of corvette information. Thanks in advance guys!
You can get the GM performance Rotors for a C5. They run about $65 each and are drilled and slotted. A very high quality rotor for a very low price. The standard C6 and the C5 rotors are the same, so you don't need anything else.
To use the Z51 rotors, you need new brackets, and contrary to what the dealer tells you, the rear calipers are different. Outside dimensions are the same, but the pistons are 3mm smaller.
So I just order "2004 GM High Performance Rotors" (front & rear) and thats all I need to get the cross drilled look? Way Cool! Is there a real performance difference?
Evidently, you are aware the rotors are drilled (according to Dave Hill) 'just for looks.' Without doing any performance driving you should do fine with drilled rotors but as a matter of principle, I'd be more inclined to modify my brakes for increased performance rather than just appearance (especially when there are known weaknesses with the drilled rotors).
I fully appreciate your point. However, my car is strictly a cruiser (poser?) so I'm just looking to improve the looks if it doesn't get into a significant cost/hassle situation. Thanks for the input. Anybody else wanna share an opinion?
I don't want to cast doubt on Corvette Pilot's information, but since my local Chevy dealers know nothing like this I will need to be positive of what I ask them to order for me. I can hear them now questioning whether this works.
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Corvette Pilot's info is correct however, you can bolt on the Z51 brackets and rotors without issue. They will look and work great. You will not have any issues. If you want the drilled look I would definitely go ahead and go with the larger Z51 rotors.
rather than the smaller C5 performance rotors.
O.K. You guys are giving me GREAT info! Now, 2nd question: I'm planning on having my tire dealer do my brakes at the same time he mounts my new Firestone Firehawk Wide Oval Run Flats. However, he says that he likes to turn even new rotors right out of the box to "make sure they are running true". I'm not sure I agree with cutting down a new rotor. If I did I'd just have him turn my old ones. Any thoughts?
OOPS! One final question: Again, I'm planning on having my tire dealer do the brakes, but he wants to use Wagner pads rather than OE (after turning the new rotors). Should I just take the car to my Chevy dealer for brakes, get the new rotors and keep it all GM?
Rockstar, no, you don't need to turn them. I do suggest either zinc or cadmium plating them to avoid rust issues. Get the Z51's. The "bigger" look, combined with drilled holes is worth it. You can get everything for under $500.
F rotors#89060328 $81.15 ea
R rotors #89060329 $67.10 ea
F brackets #88964166 $37.50 ea
R brackets #88964167 $37.50 ea
Shipping's about 30 bucks.
Your tire dealer is just trying to squeeze more money out of you by getting you to pay for things you don't need and that he probably won't even use. Find a new one or do the rotor swap yourself, it is not difficult at all.
I'm going to agree with your tire guy. I always do a light truing cut on new rotors. New rotors often have a surprising amount of run out. I like to get that down as close to zero as I can before putting them on a car. Except for the bling factor, I'd turn the original rotors as long as there's enough meat left on them. They're already seasoned, and less likely to warp if not carefully broken in than a new rotor. Generally, you go through several sets of pads before needing to replace the rotors.
I really appreciate the opinions you've all expressed here. I totally understand what you are saying Tommy, and I agree that your car looks very good. However, I tend to lean toward Pilot's advice in that I'm doing this strictly for looks and want to save as much $$ as I can. The Chevy dealer in my hometown will give me a little bit of a discount so I can probably buy all four of the C-5 rotors for about $200 vs the $500 for the Z-51 upgrade. Like Shopdog points out, this is my first brake job on this car and the rotors don't really need to be replaced anyway. It's strictly a cosmetic thing. Thanks for all your help!
