Z51 toe-link grease
Old Jul 8, 2007 | 12:57 AM
errance's Avatar
errance
Default Z51 toe-link grease
Hello,
Which grease do you guys use for your toe-links? GM-brand? Mobil1?
Are they the same? Does it matter?
Thx!
Old Jul 8, 2007 | 01:31 AM
DJackman's Avatar
DJackman
Originally Posted by errance
Hello,
Thx!
I use Mobil1. I think its better than the GM brand. Just did mines at 15K miles
Old Jul 8, 2007 | 09:15 AM
Bandit1's Avatar
Bandit1
Mobil!. You can get it at PepBoys or just about anywhere.
Old Jul 8, 2007 | 10:13 AM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
Valvoline Synthetic....no dripping like Mobil One
Old Jul 8, 2007 | 11:41 AM
calemasters's Avatar
calemasters
Mobil 1.
Old Jul 8, 2007 | 11:57 AM
Vet's Avatar
Vet
Regular standard hi-temp dino grease is more than fine.
If you don't race the car, you rarely need to grease those toe links ends.
I originally purchased a tube of Mobil 1 for this purpose and it continually dripped all over the inside of the wheels until I flushed it out and replaced with good dino grease. Many other members had the same experience with Mobil 1 grease. It may have just been a bad batch, but... I think I'll stick with dino grease anyway.
So far with the dino grease, zero drips and holding up just fine. After a year and about 10k miles, the boots are still plump and the grease inside still appears like new.
Just like the non-greasable toe links on the non-Z51 cars, if you do not track the car, you can probably get away with never greasing the links ever and they'll last the life of the car.
When tracking the car, I believe the concern is that the extreme high heat emitted from the rear brake rotors is what will kill the toe link grease (as in stomping on the brakes at 100 mph every 30 seconds or whatever, continuously)... but if you're not tracking, this is not a concern and the grease in the links should last a good long time.
Old Jul 8, 2007 | 01:30 PM
Irv's Avatar
Irv
Mobil-1 sucks.
Old Jul 8, 2007 | 02:30 PM
errance's Avatar
errance
Sorry, I should have mentionned in the original post that I do track the car.
Interesting split in this thread. Half of you say Mobil1 is good, the other half says it drips.
Old Jul 8, 2007 | 06:08 PM
DaveC6's Avatar
DaveC6
Mobil 1 drips. I bought a grease gun and loaded it with Mobil 1, but pulled back the leaver so it's not under pressure. Hung it on the wall in the garage because I'm not ready use it yet. A few days later I see this purple crap all over my tools and it was the grease gun dripping the purple Mobil 1 grease. It was 100+ degrees this week, but it proves it drips.
Old Jul 8, 2007 | 06:22 PM
theVcar's Avatar
theVcar
St. Jude Donor '08
?is this what I see on the inside of my rear rims? alittle elbow grease thats care of it though.
Old Jul 8, 2007 | 06:31 PM
Whiterock1's Avatar
Whiterock1
Go look at the thread about 0W-30!
Old Jul 8, 2007 | 06:50 PM
errance's Avatar
errance
Haha. I think the list of things that people can never agree on goes likes this:
politics, religion, and lubrication
What I'm getting out of this thread is: people use Mobil1, Valvo synth and others. Nobody is having massive suspension failures with either, but several people say M1 drips.
Old Jul 9, 2007 | 11:52 AM
JmpnJckFlsh's Avatar
JmpnJckFlsh
The dripping is caused by the oil separating from the soap base. Most greases separate to some degree, but the Mobil 1 seems to be excessive.
I went with Valvoline synthetic to avoid the problem many were experiencing...it meets the required lube specs and says so on the tube. The Valvoline also will leak oil residue out of the gun, but it doesn't drip on my wheels and that's what I meant to avoid.
To Z51 toe-link grease
