vararam question
Old Jul 8, 2007 | 01:34 PM
woodzy's Avatar
woodzy
Cruising
Default vararam question
I installed my vararam intake 2 days ago. I have put about 30 miles on since,but i notice in neutral when i blip the throttle it hesitates for a second. anyone else have this problem,or does the computer just need more time to adjust ?
Old Jul 8, 2007 | 01:42 PM
edv2122's Avatar
edv2122
have you noticed any improvement in performance?
Old Jul 8, 2007 | 01:47 PM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
Only two things are possible;
1. They all do it
2. You installed it wrong!
Old Jul 8, 2007 | 02:22 PM
not08crmanymore's Avatar
not08crmanymore
nothing like that when I put mine in.Make sure the box is tight and the area is sealed.100 miles or so for the computer to adjust.
Old Jul 8, 2007 | 02:31 PM
bunk22's Avatar
bunk22
Nothing like that with mine either. Nothing but improved performance.
Old Jul 8, 2007 | 07:03 PM
Maui's Avatar
Maui
St. Jude Donor '08
Did not have that issue when I installed mine. I've noticed a big improvement on the open road at speed.
Old Jul 8, 2007 | 07:09 PM
SpinMonster's Avatar
SpinMonster
Its a tuning issue as the VR is freeing up breathing. It will disapear with a tune.
Old Jul 8, 2007 | 07:18 PM
goatts's Avatar
goatts
You shouldn't need a tune after installing a CAI. The computer will adjust the mixture when the increased airflow is detected. Headers need a tune.
Old Jul 9, 2007 | 12:00 AM
Vetteoholic's Avatar
Vetteoholic
I'm thinking of getting the vararam for my C6. I hope I don't have this problem, though I've never heard of it so like stated above...maybe slightly off on the install?
Old Jul 9, 2007 | 12:17 AM
ZO6 Fan's Avatar
ZO6 Fan
Default Vr Cai
FYI-When mine was installed My "Check engine" light was flashing (still does) and its idling a little rough. One of the guys on the forum said I need to check if the install was done properly I.E. Sealed Completely I'm wondering if I download the Diablosport Predator handheld that will eliminate the aforementioned problems ...
Old Jul 9, 2007 | 06:16 AM
woodzy's Avatar
woodzy
Cruising
I installed it correctly! performance is definitly up. It runs smooth.It just hesitates for a split second when the throttle is blipped
To vararam question
