Suggestions comments on major mods?
One thing I am not confident about is the Moton 2 way adjustable suspension. What am I missing out on by not going with the 3 or 4 way adjustable? Should I spend the extra $5k and go with the 4 way adjustable?
1.. Cold Air Kit:
2.. Ron Davis Radiator:
3.. Xtreme Oil Coller:
4.. Custom Roll Cage:P
5.. High Compression Starter:
6.. High Volume Oil Pump:
7.. Cat back Exhaust:
8.. Kooks Headers with No cats for Race application:
9.. Racing Seat ranges from
10.. Spindle Brake Ducts for cooling:
11.. Twin Disc Carbon Fiber Clutch
12.. Drive Shaft Upgrades:
13.. CAGS Elimination
14.. Racing Sway Bar kit:
15.. Fuel System for Non-Turbo applications:
16.. 3.42 Race Built rear Diff:
17.. Ported TB and Intake:
18.. Race Brake Lines:
19.. Brembo Brake kit (fronts):
20.. Brembo brake Kit (rear):
21.. Koolmat Heat Shield:
22.. 3/8 Race Tunnel Plate:
23.. Custom Road race wheels 18x13 rear, 18x12.5 fronts
24.. Hoiser Tires: 290/33-18 (front) 310/41-18 (rear)
25.. 6 Point Racing Harness's:
26.. Full race carbon fiber body kit:
27.. Shipping for CF Body
28.. Paint the car after re-body:
29.. Moton Suspension
30.. Full Custom race tune:
31.. Take Customer supplied LS2 and bore and stroke to 427cid with all
best forged parts with LS7 heads:
32.. Port/Polish LS7 Heads:
This is a bit over my budget, but I am pulling the trigger anyway
There are IMO only a handful shops in the Country I'd turn loose with that list.
If you're doing all that I'd consider using the C5R big block.Keep us posted on your progress.
1.. Cold Air Kit:
Good luck with the build.
Not sure if you have any idea about motons but if you don't know what you're doing you'll probably do more harm than good. I'd go 2 way for sure.
I am shooting for atleast 600hp at the rear wheels, 500 isn't enough. I have a viper doing more then that now, and I don't want this car to be slower car.
1.. Cold Air Kit:
Seems like you have a great list compiled there, that will cost alot but i'm sure it will be more than worth it in the end.
Best of luck
~CHRIS
Best of luck
~CHRISThanks for the suggestion
That's some $ is no object mod list. I think you'll be better off buying the Z in the first place.
