Brake Fluid-- What Do I Use?
Old Jul 16, 2007 | 10:51 AM
NTRBL33's Avatar
NTRBL33
From: The United States of TEXAS www.corvettemotorsportsinc.com
St. Jude Donor '07-'08-'09-'10-'11
Default Brake Fluid-- What Do I Use?
DOT 3, DOT 4???? DOT 12?
whats good to use?
tx
dlj
Old Jul 16, 2007 | 11:18 AM
Ranger's Avatar
Ranger
whats good to use?
tx
dlj
Chevy spec is DOT3.
If you plan to upgrade to DOT4 in the brakes, suggest doing a full bleed of the brake hydraulics.
Best fluid comparo I've found so far. Company does not sell brake fluid, but compiled the comparo as a service to its customers.
Old Jul 16, 2007 | 11:32 AM
big bollas's Avatar
big bollas
DJ ,did you upgrade your brakes?
If so what is the DIY on the install?
I just picked up a set of C6 Z06 brakes and need to install them.
Thanks for any info
Old Jul 16, 2007 | 06:32 PM
NTRBL33's Avatar
NTRBL33
just painted the Rotors and Calipers. No upgrade.. yet...
Old Jul 16, 2007 | 06:43 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Motul RBF 600 makes for a nice upgrade from the stock fluid and is completely compatible with the stock GM fluid.
To Brake Fluid-- What Do I Use?
