C6 coupe exact weight?
Old Jul 18, 2007 | 04:08 PM
CessnaDriver's Avatar
CessnaDriver
Default C6 coupe exact weight?
Ordered a G-Tech, and I know that accurate weight is a necessary input for best calculation accuracy.
Anyone have exact weights of the various C6s?
With or without full tank of gas?
I have an 06 A6 Z51.
Thanks in advance!
Old Jul 18, 2007 | 05:47 PM
johnodrake's Avatar
johnodrake
Moderator
Coupe: 3179
If you really want to be accurate, get on a set of scales for your car.
Old Jul 18, 2007 | 06:26 PM
robvuk's Avatar
robvuk
Don't forget to add your own weight along with all the junk you normally carry in the car.
Old Jul 18, 2007 | 06:58 PM
CessnaDriver
Originally Posted by johnodrake
Coupe: 3179
Thanks!
Do you know if that is with full tank of gas or empty?
EDIT..
I just looked up "curb weight" and it says that includes full fuel.
So just need to add my own weight and small items.
Subtract for less then full fuel with a best guess of whats in the tank.
Old Jul 18, 2007 | 06:59 PM
glennhl's Avatar
glennhl
My 2LT Z51 A6 weighed 3210 pounds with about 3 gallons of gas.
Old Jul 18, 2007 | 07:06 PM
dennis50nj's Avatar
dennis50nj
i think i found the reason Glenn! the altitude it pulls harder more gravity car weighs more
CessnaDriver
Hmmm
Z51 option must add a little I think.
Old Jul 18, 2007 | 07:10 PM
CessnaDriver
2005 car and driver for a M6 Z51 had.....
Curb weight: 3224 lb
I dont know how sensitive these G-tech things are to weight.
I suppose within 50 pounds ought to be close enough.
Old Jul 18, 2007 | 08:18 PM
glennhl's Avatar
glennhl
No, your car weighs less at sea level because the denser air causes more boyancy!
The 3210 was from my memory. I just pulled up my spreadsheet. It weighed 3405 with me in it and around 3 gallons of gas. I'm right at 215, so that puts the car at 3190. The A6 is a very heavy tranny!
Old Jul 18, 2007 | 08:33 PM
dennis50nj's Avatar
dennis50nj
been meaning to weigh, but never have. i figure 3500 with me in it plus liquid and helmet
Old Jul 18, 2007 | 08:52 PM
LS1LT1's Avatar
LS1LT1
That's actually the only way to know for sure for I have yet to see two (even similarly equipped) C6s weigh the same.
Old Jul 19, 2007 | 02:00 AM
SoldSyclone's Avatar
SoldSyclone
Mine was 3280 and 3315 at the track I am 200 so my 1lt A6 with 1/8 tank is ~3100 friends 3lt z51 was 100 more
Old Jul 19, 2007 | 06:32 AM
ZLEGEND's Avatar
ZLEGEND
Thats possible but.......whats the weight when centrifical force gets intruduced to the horizontal component of Lift
Old Jul 19, 2007 | 06:35 AM
cbrf4i1's Avatar
cbrf4i1
wow, that is light, is your z51? i only got z51 option m6, it weighted in at 3130 with about same amout of gas as you. thanks
Old Jul 19, 2007 | 09:54 AM
Whiterock1's Avatar
Whiterock1
Originally Posted by CessnaDriver
Thanks!
EDIT..
Gasoline is 7# a gallon. I always thought curb weight was with an empty tank, but may be wrong.
Old Jul 19, 2007 | 01:03 PM
LS1LT1's Avatar
LS1LT1
Are you sure the scale was dead on accurate?
I also have a non Z51 1LT A6 and it weighed roughly 3406 - 3412 pounds with me and a 1/4 tank of fuel in it (on the NHRA certified/calibrated scale at Englishtown) and I weigh roughly 190 - 193.
I'm calculating around 3220+- for my car without me in it.
Old Jul 19, 2007 | 01:21 PM
cbrf4i1's Avatar
cbrf4i1
mark, i weight my car right after glennhl. so with his 2lt z51 a6 vs my 1lt z51 m6 the weight difference is like 80 lbs. there was less then 1 gal difference in fuel between our cars. i even got on the scale just to weight myself for reference. i can in at 185lb on that scale (it will only move in 5lb increment) i weight 180lb at my local gym scale.
To C6 coupe exact weight?
Old Jul 19, 2007 | 02:08 PM
LS1LT1's Avatar
LS1LT1
I think it's closer to 6 pounds, 5.8 pounds per gallon I've heard.
But either way it DOES add up, I can clearly feel the performance differences between a full tank and a 1/4 in my cars.
Old Jul 19, 2007 | 02:13 PM
LS1LT1's Avatar
LS1LT1
Well those numbers/differences do make sense though, the automatic does weigh notably more than the manual and the 2LT does weigh more than the 1LT, both cars are Z51s so that's a wash.
What I was questoning is how SoldSyclone's vehicle weight could be so low, but it is possible I guess.
Old Jul 19, 2007 | 02:52 PM
cbrf4i1's Avatar
cbrf4i1
yeah, you right, i totoally miss the part soldsyclon'e has A6.
