Want gears, need advise
Old Jul 21, 2007 | 05:21 PM
06 Monterey Red's Avatar
06 Monterey Red
Originally Posted by Goodwood
Hard to make a recommendation w/o your stating if you've got a manny tranny or an auto, and how much hp you're running. With 500+rwhp, I think my 427ci M6 is perfect with 3.90s, but if it was stock hp, or close, I would've went with 4.10s.
Original poster here... My car is a C6 coupe with 6 speed MT. I don't have any mods yet and it's very likely that I wont do much more than simple bolt-ons and perhaps a tune. Since we get better gasoline in Georgia than they have in Cali and other places, I understand that a good tuner can get a decent increase in power with something like HP tuners by tuning the car for the higher octane gasoline and perhaps a bit more aggressive timing and fule maps.
I think that I'll definitely get the gears because it seems that it's a great first mod that will really improve the performance of the car.... The only thing I need to know is where to get these gears and who is a good installer. I could try to get the gear set and just replace the originals in which case I would have the OEM gears to replace them if needed. I don't know how hard it would be how change the gears in the Vette... My buddy did his Mustang and he was ver successful. If the job is not too much more difficult, we could tackle ourselves. Otherwise, I can just buy a ready to install rear end and go that way.
It's very interesting to see that gears and rear ends for Corvettes are not nearly as plentiful as for other RWD muscle cars. The world is awash with rear ends and gears for old and newer muscle cars, but the Corvette stuff is notable for it's scarcity....
Old Jul 21, 2007 | 06:16 PM
JD21029's Avatar
JD21029
So any recommended installers for a guy in Maryland?
Old Jul 21, 2007 | 10:09 PM
dtwalkerfl's Avatar
dtwalkerfl
You guys with the A6's and 3.15 gears: have you had your speedo recalibrated?
Old Jul 22, 2007 | 09:52 PM
kenw's Avatar
kenw
VIR
Phil(Dynotech) did it as part of the overall tune on my car. Since mine was the first 315 it was a custom tune. Phil had to do alot of pulls to do it but it sure does work well.
Old Jul 22, 2007 | 10:14 PM
ROD BROWN's Avatar
ROD BROWN
Default Why did GM make this change?
My 06 w/z51 package came with 3.42.What is the advantage of GM installing 2.73 in the new cars?Wouldn't performance suffer?
Old Jul 23, 2007 | 01:41 AM
Fuego's Avatar
Fuego
that gearing is for auto's.
Old Jul 23, 2007 | 10:54 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Tony in Gaithersburg
or
ZIP in Richmond
Old Jul 24, 2007 | 01:59 AM
ScottJ03's Avatar
ScottJ03
Default Recalibrated. Dead on ***** Accurate
Tested with one of the things on the side of the road. And was exact.
HP Tuners used to update ECM. Can't say enough about gears!!!
