Vararam install...OK Uncle!
Old Jul 20, 2007 | 09:36 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Originally Posted by MagicMtnDan
No one appreciates a one word post like this expecially not the manufacturer. If you have a negative opinion you want to express the LEAST you could do is explain WHY that's your opinion.
Your BS post impacts the manufacturer, the distributors and the prospective customers. Bad (negative) news travels a lot faster on the Internet than any positive information.
Show some class and explain your post or delete it.
I have a different cai, but man posting negative criteria about the Vararam just because you having problems with the install, does not make it an inferior cai. I think your frustrations are due to the fact that the distributor doesn't return your calls.
Old Jul 20, 2007 | 11:41 PM
edv2122's Avatar
edv2122
I think he was referring to another member's post however my frustration is partly with the distrubutor and partly the fitment issues with install. I would not say its inferior with performance results although I have not got a chance to really test it but if it does not fit properly with the addition of the throttle body spacer a solution should come with the kit instead of having to figure something out on your own.
Old Jul 21, 2007 | 12:10 AM
dennis50nj's Avatar
dennis50nj
you dont have to change nothing. i put it in just fine with stock accordian. heres what you do. cut the front off the shrow out to the humps half way into the humps on the fram. put the bottom section in with the two half biscuts in the grill . once in look from front to make sure ,now tighten lower frame suport. now push top section on throttle body rubbers , then lower and adjust to bottom .
Old Mar 28, 2008 | 11:10 PM
HorsePower Junkie's Avatar
HorsePower Junkie
St. Jude Donor '20-'21-'22-'23
Great info! Thanks guys!
Old Mar 28, 2008 | 11:55 PM
Slick0478's Avatar
Slick0478
I just installed mine without spacer and had no probs but I took the shroud out to cut it and went a 1/8" bigger then template
I also took MAF off and attached to the Var and put in all in as one peice and just had to wiggle a bit to get lined up
If you need any help I'm in north NJ bergencty
Slick
Old Mar 29, 2008 | 01:39 AM
RULEMKR's Avatar
RULEMKR
St. Jude Donor '09
Originally Posted by VaraRam Industries
Please anyone that is having any problems with installation please call us at 713-899-6456(tech line) or 866-507-2648 or via email at sales@vararam.com and we will be glad to help you!!! Also as you all can see - members on the forum are more than willing to help and have some practical tips and hints just for the asking!! Thanks to all for those helpful - practical tips!!!
Steve
He; (Steve) speaks the truth. I had problems with bottom half of my
unit seperating at the seam. Steve had me another unit shipped quicker
than I could respond to his e-mail. I offered to pay for shipping and he
refused to accept it stating only that he was sorry that the bottom
section failed. Vararam Industries was supportive when I first installed
my unit and still services what they sell. I've bought items way more
expensive than a CAI and still did not get this kind of service or support after the sale. Vararam & Chuck Cow are a lethal combination.
