Vararam install...OK Uncle!
Old Jul 19, 2007 | 06:42 PM
edv2122's Avatar
edv2122
Default Vararam install...OK Uncle!
I am trying to install a vararam unit in my 06 coupe. I cut out the shroud plenty big, put the unit together outside the car and it wil ljust not line up with the throttle body spacer. I spent the past 4 hours installing it backwards and forwards and even went out to buy flexible coupling and still no dice. The only way it fits is with the scoop pointed on a downward angle with the bottom of it below the bumper grill opening. I did place the scoop on the two bumper tabs on the inside and it just pops off when the couplings are attempted to be put together. Its almost comical how bad the fitment of this unit is. Can someone PLEASE tell me what I am doing wrong. Did they send me the wrong unit? Does the Z06 unit look anything like the C6 unit? I have tried putting the maf and throttle body couplings together in every imaginable combination and nothing is working.
I have done two cold air intakes and a couple top breathers on my C5's and never an issue. Why does this Vararam remind me of some kind of back yard, mickey mouse contraption.
Old Jul 19, 2007 | 07:13 PM
Pat Salerno's Avatar
Pat Salerno
I had no problem with mine.
here's a link to the Vararam web site to show how it should go iin.
If this doesn't help , contact Vararam ...they have been extremely helpful to folks in the past.
http://vararam.com/sc1.html
also here's the link to the PDF instruction sheet in case you don't have it.
http://www.vararam.com/C6-snakecharmer.pdf
Pat
Old Jul 19, 2007 | 07:29 PM
BADASSBU's Avatar
BADASSBU
Where in nj are you ? Your more than welcome to look at mine, I had no problems like that installing mine.
Old Jul 19, 2007 | 07:46 PM
edv2122's Avatar
edv2122
I know they were back ordered for awhile and maybe this batch got rushed because there is no way this thing will fit. I tried multiple different sized couplings including flexible hose and the stock piece none of which work.
what makes this so bad is I waited just about a month for this thing and it will be a chore to return it to RPI as they do not answer or return phone calls.
Old Jul 19, 2007 | 08:14 PM
BADASSBU's Avatar
BADASSBU
Like I said where do you live? I'am in Toms River NJ if your close I can help you. pm me if you need help. , Kevin
Old Jul 19, 2007 | 08:23 PM
Finster07's Avatar
Finster07
I had EXACTLY the same experience. My vararam would absolutely not line up with the spacer. If I got even close, the intake was pointing down and the bottom 1/4 was blocked by the lower bumper. I finally took the spacer out and it lined up perfectly. I called Vararam and they said the spacer was not designed specifically for the Vararam and implied that I wasn't the first to say it didn't fit. I feel your pain. My spacer is now a paperweight on my desk. Let me know if you get it to fit properly. Good luck.
Old Jul 19, 2007 | 08:28 PM
asian-winkie's Avatar
asian-winkie
I had a vararam on my 07 C6, one word....JUNK
Old Jul 19, 2007 | 08:41 PM
Miaugi's Avatar
Miaugi
Originally Posted by asian-winkie
...one word....JUNK
JUNK = Just Unbelievable Now Kicks-***!
Old Jul 19, 2007 | 08:42 PM
hellotbone's Avatar
hellotbone
They all install with the spacer on a downward angle. Have a look at them in the posts on the forums.
Old Jul 19, 2007 | 10:23 PM
edv2122's Avatar
edv2122
Ok, finally got the damm thing in and lined up. I had to open the shroud a good bit more then the template and I used two new couplings I got from pep boys and had to thread one with a hole for the breather thing. It is not perfect but it is buttoned up and lined up, no leaks.
I was looking at the bottom scoop and where the two pieces are joined together at the joint, one side is opened up a bit. Looks like I need a new bottom piece of the box and if I can find couplings that are .25" longer a piece I will be in business.
Its ok for now. the performance gains better be worth the ugly looks and fitment issues.
Old Jul 19, 2007 | 11:27 PM
NC-LT4's Avatar
NC-LT4
Glad that you finally got it figured out and installed.
My suggestion to anyone with an install question about the Vararam is to call their technical support people. They were more than helpful. I called them numerous times and they were very patient and helpful each time.
I've seen and used a lot of cold air kits over the years and I wouldn't call the Vararam Junk.
Old Jul 20, 2007 | 10:02 AM
BC Bob's Avatar
BC Bob
Pull this thread up:
http://forums.corvetteforum.com/show...hlight=vararam
Post #190 lists what I had to do to tweek the Vararam so it's a perfect fit.
And it is not "JUNK". With a little imagination, mechanical aptitude and patience, it goes on beautifully.
Old Jul 20, 2007 | 10:54 AM
ShockerRacing's Avatar
ShockerRacing
Here is my Vararam install write-up: http://www.shockerracing.com/phpBB2/...pic.php?t=1789
Old Jul 20, 2007 | 11:00 AM
JLMounce's Avatar
JLMounce
On mine, I had to reposition the orange coupler that attached the throttle body to the airbridge. If you haven't messed around with that piece you might try it.
Old Jul 20, 2007 | 11:32 AM
not08crmanymore's Avatar
not08crmanymore
It's known that the thing that comes with the V-RAM for cutting isn't quite right.Glad you got it on.
Old Jul 20, 2007 | 01:16 PM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
Please anyone that is having any problems with installation please call us at 713-899-6456(tech line) or 866-507-2648 or via email at sales@vararam.com and we will be glad to help you!!! Also as you all can see - members on the forum are more than willing to help and have some practical tips and hints just for the asking!! Thanks to all for those helpful - practical tips!!!
Steve
Old Jul 20, 2007 | 01:32 PM
edv2122's Avatar
edv2122
You got rid of the stock accordian coupler like I did. Is you breather valve (I think thats whats it called) threaded all the way through the new silicone coupler you used? The stock piece had it set up flush with the accordian style coupler, mine it is sticking in all the way through my new silicone coupler which puts it in the path of incoming air. I am trying to figure out a way to correct that.
To Vararam install...OK Uncle!
Old Jul 20, 2007 | 03:42 PM
Maui's Avatar
Maui
St. Jude Donor '08
I had no problem with mine. Everything lined up just fine.
Old Jul 20, 2007 | 04:36 PM
MagicMtnDan's Avatar
MagicMtnDan
No one appreciates a one word post like this expecially not the manufacturer. If you have a negative opinion you want to express the LEAST you could do is explain WHY that's your opinion.
Your BS post impacts the manufacturer, the distributors and the prospective customers. Bad (negative) news travels a lot faster on the Internet than any positive information.
Show some class and explain your post or delete it.
Old Jul 20, 2007 | 09:28 PM
welcome2try's Avatar
welcome2try
From: Objects in your mirror are losing , Long Island, NY
St. Jude Donor '08
Steve
I have the Vortex ram air, Carbon fiber neck, clear box, just kick Azz set up, and great performance. However, hats off to Vararam industries, for attempting to help you out..Good luck..
