rear end chatter
Old Aug 3, 2007 | 12:23 AM
StarJack's Avatar
StarJack
Originally Posted by KarlK
My chatter is gone but I have this slight popping / clunking sound at low speeds, going straight over smooth or uneven surfaces. Sounds like a suspension bind, U-joint, differential back lash or ????
That does not sound good! Sure you got all the pieces that may have broken off?
Old Aug 3, 2007 | 12:32 AM
KarlK's Avatar
KarlK
From: Beats UD regularly playing 3D chess, and at life
pieces broken off?
There is no noise at speed, acceleration, etc. just from 5-30 mph or so.
This topic has been hashed out over on General for several weeks, several threads. Some say loose calipers, loose sway bars, some say dealerships can't pinpoint it, etc.
I've tightened every bolt in the rear, silicone sprayed every rubber bushing, check shock mounts, exhaust system and mounts, axle nuts, etc. noise is still there.
I'm reluctant to take mine in without a know fix.
Old Aug 3, 2007 | 12:48 AM
StarJack's Avatar
StarJack
pieces broken off?
Meant a small piece of the tip that you were using to add the fluid, but I think I misunderstood what you were describing, and I certainly agree with reluctance to take it in w/o knowing the fix. Hope you get it figured out.
Old Aug 3, 2007 | 02:10 AM
knkali's Avatar
knkali
I was going to ask a question like was it lowered but I am sure you cover all that already to death.
Old Aug 3, 2007 | 08:17 AM
KarlK's Avatar
KarlK
Yes I have it lowered but not down all the way on the factory blocks. I lowered it the second day I had it and for 1 1/2 years with no noise.
I even raised it up a little, no difference.
Old Aug 6, 2007 | 11:11 AM
wsharp24's Avatar
wsharp24
did a bunch of tight turns and the noise is gone again.
Okay, makes sense now. I'm hoping that AMSOIL is the answer.
I hear that the 07s are having the same problem.
WTF does it take for GM to figure out this problem? I have heard that this has been a problem for over 10 years...GEEZ.
Fingers crossed for AMSOIL to be the true fix.
Old Aug 6, 2007 | 11:33 AM
dtvet's Avatar
dtvet
Has GM addressed these common issues in later 07's or 08's? Now I am concerned, since I just ordered an 08. . . . the last thing I need is another problem car. . .
Clutch issues
CAGs wiring issues
Rear differential seals leak issues
Differential chatter issues
Excess heat in console issues
Engine oil leaks
Roof's flying off issues
anything else?
Old Aug 6, 2007 | 11:59 AM
carpe dm's Avatar
carpe dm
Originally Posted by dave pawlowski
1. Would overfilling the diff case help? It would raise the lube level.
2. Other than the noise, is it really a problem? It seems to go away as soon as I drive a short distance.
Don't "overfill" the diff. Hard to do, but I suppose you could..... It will increase pressures and will wind up coming out the breather and making a mess.
Old Aug 6, 2007 | 09:41 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
C5/C5 Z06 has had its fair share of diff problems, but not the same one's I'm reading about for the C6. Most C6 diff problems seem to be related to low speed, tight corner, clutch plate chatter, which is all but unheard of for the C5. The most common C5 problem seems to be a leaking left axle seal (which I had as well). I spend a lot of time on the GTO and CTS-V forums, and those cars seem to have diff whine as the major issue. Guess if it's not one thing, it's another.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
