Clutch upgrade
Old Aug 4, 2007 | 12:18 AM
PaulC6Z's Avatar
PaulC6Z
Default Clutch upgrade
Hey Guys,
Sorry for the naive question. I have a 06 c6 mn6 with Corsa Sports and a VaraRam w/Tb. I want to upgrade the clutch. What more should I do if the clutch is a Stage 5 clutch? Is it a O.K. just to replace the clutch? Thank you in advance.
Old Aug 4, 2007 | 03:06 AM
Wayne O's Avatar
Wayne O
CF Senior Member
No offense intended but I'm curious why you would want to upgrade your clutch? Are you having problems with your stock clutch...what do you hope to gain?
Old Aug 4, 2007 | 10:28 AM
PaulC6Z's Avatar
PaulC6Z
The stock clutch gets stuck if I try to launch at more than 3500rpm. No offense taken. Just want a better product.
Old Aug 4, 2007 | 10:37 AM
Ranger's Avatar
Ranger
Make a quicker clutch release; refrain from intentionally slipping the clutch.
Hold the launch rpm and then do a very fast release, followed by a calibrated throttle squeeze, rather than a stab-to-the-floor.
Also want to check your clutch fluid....Taking Care of Your Clutch
Ranger
To Clutch upgrade
