help needed! - experts only please!
Old Aug 5, 2007 | 10:39 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Default help needed! - experts only please!
OK.. this is my nightmare!!
I changed my MAP sensor twice a week now, can't figure out what is the problem(s)!
every time I hook up the diablo to see what codes I have, I get the MAP sensor.. MAP sensor.. MAP sensor.. MAP sensor.. MAP sensor..
some will say "you have a MAP problem" I ALREADY KNOW THAT THANKS A LOT! but what is causing this? is there any problem with my car/mods? - I got "Unknown" code too! what the hell is that too?
Thank you!
Old Aug 5, 2007 | 10:47 AM
AU N EGL's Avatar
AU N EGL
Thank you!
Then dont hook up the diablo, that could be the problem. Find a tuner who uses a real tuning program.
Sorry to be so direct, but we read alot about hand held tuners turning into major problems
Old Aug 5, 2007 | 12:28 PM
Nicodemus's Avatar
Nicodemus
Is the car stock? A larger cam can cause MAP sensor codes.
Old Aug 5, 2007 | 04:34 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
mods: maggie, lpe cai, stealth 2 cam, meth.
Old Aug 5, 2007 | 05:47 PM
1bdasvt's Avatar
1bdasvt
St. Jude Donor '06-'09
Mohd,take it to a "Human tuner"!!!
Good luck with it!!
Old Aug 5, 2007 | 08:56 PM
cerino2000's Avatar
cerino2000
yep, not enough info. What all has been done to the car. Why was the MAP sensor changed at all?
Old Aug 6, 2007 | 02:13 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
George, I did that yesterday. he told me everything is fine but the MAP sensor, I changed it and all was OK.. but guess what is my new problem? (AGAAAAIN) the MAP sensor!!!!!!
Old Aug 6, 2007 | 02:23 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
ok.. I felt the car lost power, and there is a strange voice when car's sucking air, I hit the gas pedal more but the car wont rrespond! went to my tuner to do some checking and I saw "Manifold Absolute Pressure" changed it 3 times in one week!
Old Aug 6, 2007 | 02:40 AM
dansdrm's Avatar
dansdrm
Default Call the dealer
Old Aug 6, 2007 | 03:41 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
the dealer? yeah right! I remember that day when I wanted to refill my A\C and the head "pro" mechanic guy told me to change my radiator to a heavy duty one!!
Old Aug 6, 2007 | 05:31 AM
zo6112's Avatar
zo6112
Old Aug 6, 2007 | 09:52 AM
1bdasvt's Avatar
1bdasvt
Living in Kuwait,...that might not be such a bad idea!!
Old Aug 6, 2007 | 10:10 AM
not08crmanymore's Avatar
not08crmanymore
Sorry but the diablo doesn't seem to be the problem here,his MAP is the problem.I would venture to say that all those mods are causing your issues,exactly why however,I can't say.Good luck in finding the cause of the problem.
Old Aug 6, 2007 | 04:11 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Aug 6, 2007 | 05:53 PM
Gotcha's Avatar
Gotcha
Is the Diablo programmed for the supercharger??? Who installed it anyway and do they know you're reprogramming the PCM?
I have a maggie on my 05 with a 2 Bar map sensor (non stock) with EFIlive programming. Some tuners go with a 2 or 3 bar map sensor that has different outputs and require specific programming.
I'm not sure whats going with your setup. If youv'e got a good map sensor with the right programming I'd start by checking the voltage output for the map sensor traced all the way to the PCM. It should be 0-1v. You could have a pinched wire or something?
Old Aug 7, 2007 | 04:08 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
I'm not re-programming, I am checking for trouble codes.
should I use a special MAP?
To help needed! - experts only please!
