Brake Bleeding?
Old Aug 6, 2007 | 04:53 PM
1yelovet's Avatar
1yelovet
Default Brake Bleeding?
Installing new powder coated calipers. My question is what procedure do I follow with Speed Bleeders and do I need a hand held computer to program the ABS system?
Old Aug 6, 2007 | 06:17 PM
1yelovet's Avatar
1yelovet
ttt?
Old Aug 6, 2007 | 09:18 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
Jeff,
This is one of the best written guides to bleeding brakes.
http://www.zeckhausen.com/bleeding_brakes.htm
Speed bleeders won't change the procedure any really, they will just ensure air doesn't back into the system. You still need someone to watch the fluid flow to ensure all air is out.
Also,
I like to stretch a latex glove over the resorvoir and replace the cap before starting to minimize fluid loss, but then I remember, your brakes have been off for a couple weeks now anyways.
No computer is needed, as long as your resorvoir hasn't run dry.
Mike
Old Aug 6, 2007 | 10:05 PM
aTX427
Guest
Posts: n/a
It is a one person job with a Mytivac (sp?). $35 at autozone.
Old Aug 7, 2007 | 11:27 AM
basshed's Avatar
basshed
Just used it two weekends ago! Just have to double check when you pull fluid out that it doesn't drain the reservoir if doing it solo. took me 10 minutes tops. Should go even quicker with speed bleeders since it won't back-fill into the caliper.
Matt
To Brake Bleeding?
