Amsoil Differential Fluid
Old Aug 9, 2007 | 05:24 PM
SFHC6's Avatar
SFHC6
Default Amsoil Differential Fluid
I was going to take my '05 Vet to the dealer for the TSB for rear grinding noise until I read the threads about the noise coming back after a couple thousand miles with GM Fluid.
I just changed mine with Amsoil, and noticed an immediate difference. Now we will have to see if the noise stays away... time will tell! I am impressed so far... hopefully I did not jinx myself.
Old Aug 9, 2007 | 06:41 PM
CessnaDriver's Avatar
CessnaDriver
GM recently changed to using a double dose of the friction additive when you change the gear oil.
So I did that myself. Will also do some pre-emptive figure eights when the car sits for more then a day.
If all that fails, I'll move on to another brand for the gear oil.
There are enough of us experimenting that over time a winning method or two should become clear.
Old Aug 9, 2007 | 08:06 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Amsoil is still working for me almost a year and a half later.
CessnaDriver
Outstanding! How many miles is that?
Old Aug 9, 2007 | 09:21 PM
porterrw's Avatar
porterrw
Default Just add additive?
My local Mobel 1 Quick Change Service suggested just adding the GM additive to my O7 with 5000 miles, after they saw the state of the lube. They didnt buy any issue of varnish buildup on the disks. I had grinding for the last 2500 miles. They said just more additive is needed in my case. It cost just $13 installed and has worked so far, for the last 2 weeks. I like this oufit because they use pits, no lifting hazard, I can watch them and there is little wait. If the grinding returns, I'll do a $60 Mobil 1 synthetic LS differentiall lube change and supply my own Amsoil synthetic LS additive, available from Amsoil Web site.
Old Aug 9, 2007 | 09:22 PM
ByByBMW's Avatar
ByByBMW
14,000 +/- can't give you exact # car died, dead ECM. Hopefully back tomorrow.
Old Aug 9, 2007 | 11:26 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Thanks for the report. I too hope the AMSOIL Severe Gear 75w90 helps keep your diff quiet for a long time.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Aug 9, 2007 | 11:51 PM
knkali's Avatar
knkali
best fix out there. So far subdriver's stuff works. Get it
Old Aug 10, 2007 | 12:28 AM
glennhl's Avatar
glennhl
When you guys go with the Amsoil, are you still using the GM posi additive?
Old Aug 10, 2007 | 12:42 AM
Viprklr's Avatar
Viprklr
glennhl,
I used Amsoil's additive instead of the GM stuff. So far so good with mine. Amazing how quiet the car is after the switch. Now I can just get in and drive without constantly listening for the chatter.
Matt
Old Aug 10, 2007 | 12:59 AM
Ranger's Avatar
Ranger
Here is a lucid explanation of the working of posi-traction, its characteristic chatter, and the role of an additive in quieting the chatter.
AMSOIL Slip-Lock Differential Additive Write-up.
Ranger
Old Aug 10, 2007 | 01:09 AM
glennhl's Avatar
glennhl
Originally Posted by Viprklr
glennhl,
Matt
Old Aug 10, 2007 | 09:05 PM
C66 Racing's Avatar
C66 Racing
Though the AMSOIL Severe Gear Extreme Pressure Synthetic 75w90 comes with additive already in it, the C6 diff appears to work best with more. For my C6 customers, I recommend one bottle of the AMSOIL Slip-Lock Additive Ranger linked above (and thanks for that ) which is effectively equivalent to GM fluid and two bottles of GM additive.
Note though that in the C5 and other cars I don't recommend any extra additive. I don't use extra additive with this same fluid in my 02 C5 Z06 or my 06 CTS-V.
Old Aug 10, 2007 | 10:01 PM
Ranger's Avatar
Ranger
^^^ Hey Subdriver.
Most of the C6Z owners in our club continue to have growling diff clutches after the second swap of GM-brand fiuid and then the revised clutch-pack with GM-brand fluid plus two servings of the friction modifier.
I'm considering adding a bottle of the Amsoil Friction Modifier to the existing GM fluid in my diff (first swap done under warranty 5K miles ago). Mine is noisy despite a routine of figure-8s to keep the fluid distributed. A small test.
Ranger
Old Aug 11, 2007 | 11:37 AM
C66 Racing's Avatar
C66 Racing
Ranger
Certainly couldn't hurt and it would be interesting to see if one more bottle of friction modifier helps.
But... it appears from what I've read that the diff clutch growl is very sensitive to dirty fluid, as well as the afformentioned keeping the fluid in the clutch packs. Most of the threads I've read on this issue seem to indicate that changing the fluid momentarily cures the problem. Using AMSOIL's Severe Gear seems to keep the problem away longer. That may be due to the fluid being better at preventing wear, thus minimizing the particle buildup in the diff, or it may be due to different characteristics of the basestock resulting in the fluid staying in the clutch packs better... or likely some combination of both.
Old Aug 11, 2007 | 12:34 PM
Dave O's Avatar
Dave O
I changed my oil to Amsoil a few weeks ago and also added a bottle of the Amsoil Slip-Lock. My chatter is now gone.
Old Aug 11, 2007 | 12:56 PM
Ranger's Avatar
Ranger
How many miles on the car? And how many miles since adding the Amsoil Slip-Lock?
TIA,
Ranger
To Amsoil Differential Fluid
Old Aug 13, 2007 | 11:00 AM
DOUG @ ECS's Avatar
DOUG @ ECS
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
We have done the same with a few customers also, so far so good, for some time now too.
Amsoil has became our main oils used years ago, and we never looked back.
Old Aug 13, 2007 | 12:25 PM
glennhl's Avatar
glennhl
One question. I would think that the main reason the chattering goes away with the use of Amzoil and the additive is that it is more slippery (is that a technical term?).
However, if it's more slippery, doesn't that mean that the clutch plates do not grab as well and therefore the Positraction unit doesn't perform as well? Wouldn't it have a tendency to not transfer the torque as much and let the one tire spin more?
Thanks,
Glenn
Old Aug 13, 2007 | 09:36 PM
Dave O's Avatar
Dave O
TIA,
Ranger
It started to chatter at around 9000 miles. I did a bunch of figure 8's as some suggested but the noise would not go away. After changing the oil, the chatter completely went away.
I decided to go with Amsoil as so many had tried having the dealer change the oil with the GM additive but the chatter seemed to come back in the majority of the posts. The posts in regards to Amsoil seemed a little more promising. Anyway, I have around 400-500 miles on the car since the change. I'm keeping my fingers crossed that the chatter stays away.
