Code P0172
Old Aug 13, 2007 | 09:45 PM
EuroRod's Avatar
EuroRod
Default Code P0172
I threw a P0172 tonight. Cruising at 70 and bam, there it was. Reader says rich on bank 1. Any ideas as to what could cause this? Thanks.
Old Aug 14, 2007 | 04:19 AM
JSVet08's Avatar
JSVet08
A few years back one of my converters was acting up and threw this code. A new catalytic converter solved my issue.
Old Aug 14, 2007 | 07:35 AM
AutoCutter's Avatar
AutoCutter
Vacuum leak
Old Aug 14, 2007 | 07:54 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Mine is P0108 "Manifold Absolute
High Voltage" I already know that's my MAP sensor, I changed it twice
in 9 days.. is that code causing hp/power issues to me or not? am I
loosing power? what should I do to solve the problem once and for all?
I cleared it like 3 times with my Diablo Predator but it still there!
Old Aug 14, 2007 | 08:53 AM
AutoCutter's Avatar
AutoCutter
Intake vacuum leak is were I would look first. MAP Connectors may be broken or dirty.
Old Aug 14, 2007 | 09:07 AM
EuroRod's Avatar
EuroRod
Wouldn't a vac leak result in a lean condition, not rich? For a while I was blowing intake manifold gaskets when under boost, and it was throwing a lean code on cylinder bank one. Discovered a gasket failure fron a manifold issue. Replaced the manifold, and have not had that code since. But, this rich code has me puzzled.
Old Aug 14, 2007 | 10:07 AM
Brett Hunter's Avatar
Brett Hunter
It could be a faulty MAF sensor or something as simple as contaminated fuel. Did it set any other DTC's?
Old Aug 14, 2007 | 11:01 AM
EuroRod's Avatar
EuroRod
No other codes or messages in the DIC. I erased the code, and we'll see if it returns.
Old Aug 14, 2007 | 02:49 PM
AutoCutter's Avatar
AutoCutter
I struggle with this code for almost a year with my 3.8 1997 Gran Prix-the leak was a very small leak by the fuel regulator. By the way, if the car thinks it is running lean because of a vacuum leak, it responses by increasing the fuel load, hence the error is seen at the O2 Sensor. Good luck!
Old Aug 14, 2007 | 06:13 PM
haljensen's Avatar
haljensen
RE. P0172, the '05 Service Manual says;
Fuel contamination, such as water or alcohol, will affect fuel trim.
A malfunctioning MAF sensor can cause a rich condition and set this DTC.
Review the Failure Records with a scan tool. If an intermittent condition is suspected refer to page 8-892.
Old Aug 14, 2007 | 06:44 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Thanks!
To Code P0172
