Extremely quick C6 brake question.....
Old Aug 14, 2007 | 01:37 PM
QUASAR's Avatar
QUASAR
Cruising
Default Extremely quick C6 brake question.....
Does the C6 caliper (not Z51 or Z06) use the middle anti rattle spring? LS1 fbody and C5 calipers are identical in shape and size and use the same 3 metal pieces inside for the pad to float on. The newer base C6 caliper is the same with exeption of the middle of the caliper. The "window" in the middle is smaller and the fbody/C5 anti rattle spring will not fit. Does the C6 use its own smaller spring, or does it not use one at all?
If I had a C6 out here in the parking lot i'd go take a peek real quick but there isnt one.
Old Aug 15, 2007 | 04:51 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
No it does not the bridge metal trim was removed on the C6.
Old Aug 16, 2007 | 07:35 AM
corvette pilot's Avatar
0corvette pilot
Former Vendor
nope, neither the front nor rear use those clips anymore.
To Extremely quick C6 brake question.....
