tunnel plate bolts - torque specs?
Old Aug 16, 2007 | 11:41 AM
john351's Avatar
john351
Default tunnel plate bolts - torque specs?
Did a search for the torque specs on the tunnel plate bolts and only found 89 in/lbs?
Is this a typo for Ft/Lbs? and...89 seems pretty high and arbitrary.
Does anybody know the torque specs?
Thanks!
Old Aug 16, 2007 | 11:45 AM
CraigE's Avatar
CraigE
89 inch/lbs is not a typo.
Old Aug 16, 2007 | 11:47 AM
john351's Avatar
john351
Thought most torque specs were in FOOT/lbs. Not true?
Old Aug 16, 2007 | 12:20 PM
DUMAN's Avatar
DUMAN
St. Jude Donor '10
not true torque specs are alson in inch #
Old Aug 16, 2007 | 12:21 PM
xs650's Avatar
xs650
When you get down to such low torque values, inch-lb is common in the US.
That's off the bottom end of the scale on most 1/2 drive torque wrenches and US 1/4 drive wrenches usually use inch-lbs.
Old Aug 16, 2007 | 01:14 PM
john351's Avatar
john351
Thanks for edumacating me!
Any idea of a rough foot/lbs conversion?
Old Aug 16, 2007 | 01:39 PM
glass slipper's Avatar
glass slipper
The exact conversion is 12 inches= 1 foot.
So if you have 120 inch-pounds, divide by 12 to get foot-pounds...120 inch-pound=10 foot-pounds. Multiply torque in foot-pounds by 12 to get inch-pounds.
Also, foot/pounds means foot divided by pounds which is not the correct way of expressing torque. Torque is a force acting through a distance so if you have a 10 pound force pushing on a two foot bar, you multiply 10*2= 20 foot-pounds of torque.
Old Aug 16, 2007 | 03:47 PM
Joe Lynch's Avatar
Joe Lynch
St. Jude Donor '09-'11
7-8 ft-lbs. Just snug them with a 1/4" drive ratchet.
Joe
Old Aug 16, 2007 | 03:57 PM
john351's Avatar
john351
Joe
Thanks to Joe for putting succinctly - I calculated 7.4 ft/lbs!
Thanks to all for the help!
Old Aug 16, 2007 | 06:11 PM
rwebcon's Avatar
rwebcon
These bolts are very soft so go easy!
Old Aug 17, 2007 | 02:34 AM
Carnac's Avatar
Carnac
Default Just did my Tunnel Plate...
I just installed an Elite Engineering Tunnel Plate (1/4" with insulation (thermal abs)) at the same time as Corsa Sports and X pipe.
The 89 inch/pound or 7.4 foot/pounds seemed low to me initially. I used a Craftsman 3/8" short handled (12") torque wrench. I had a Craftsman long handled (18") torque wrench, but it didn't work below about 10 foot/pounds. The 12" long torque wrench (on sale for $69) worked fine at 89 inch/pounds.
I used an 8 mm socket with a 6" extension. The 89 inch/pounds ended up feeling about right for the size of the bolts.
One thing I did find - when I put the car back on the lift a week later to re-torque the exhaust bolts; all of the tunnel plate bolts needed about a 1/4th turn to get back to 89 inch/pounds. Maybe due in part to the thermal insulation, but I would suggest that you check the torque of your tunnel plate a week or two after install (easy to do even with the x-pipe in-place).
Cheers - Jim
To tunnel plate bolts - torque specs?
