CVJ boot clamp problem ...... HELP
Old Aug 17, 2007 | 07:32 PM
CraigE's Avatar
CraigE
Default CVJ boot clamp problem ...... HELP
My car is in the shop to have a cv joint boot replaced and the large outboard clamp has become a major challenge. It seems every time they try to tighten it, the tabs (dawgs) that keep the band tight, break.They are using a special tool and are not having a problem with the smaller inboard clamp but have ruined four clamps and are down to the last clamp.
Is there a trick to this ???
Old Aug 17, 2007 | 11:25 PM
drivinfast's Avatar
drivinfast
I had the rear boot replaced, only came with one clamp had to get it right the first time. the tool looks like a big pair of pliers with pincers. that goes in the tabs for the clamp. dont oversqueeze then we used a screwdriver to mash the prongs into the slot they went in. obviously takes two people. Real screwey design IMO
Old Aug 17, 2007 | 11:46 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
So why not just use a screw type hose clamp?
To CVJ boot clamp problem ...... HELP
