Question for the tekkies
Aug 18, 2007 | 10:35 PM
St. Jude Donor '11-'12
I have a big problem.
I have rotor envy. :o
On my new 07 Vert there are these tiny little dinky non drilled rotors, where the other one had the z51 pkg, nice big huge slotted rotors.
What can I put in to fill the hole? I do not think Z06 rotors will work. Do I have to change brackets and calipers too?
Aug 18, 2007 | 10:38 PM
hehe
forgot to add email notification
Aug 18, 2007 | 10:54 PM
Quote:
Originally Posted by
Ken02busa
If you want cool and good rotors and are willing to spend - check out Baer Eradispeed rotors.
Aug 19, 2007 | 03:03 PM
Are you sure the Z51 rotors/calipers will not fit? I have a Z51 and the wheels are the same size. Hope this helps.
Aug 19, 2007 | 03:09 PM
brakes
If they would fit that would be very cool, but that is why I am asking.
Thanks for the reply!
Aug 19, 2007 | 03:18 PM
johnodrake
That's what I bought. They look great and the car still stops!
Aug 19, 2007 | 05:16 PM
baer
you guys are spending 4g+ on brakes?
Aug 19, 2007 | 06:23 PM
St. Jude Donor '06-13,'16-'17, '19
The drilled Z51 rotors will work fine on your C6. You will need the Z51 caliper brackets too. You can use your current calipers and brake pads.
Gene Culley sells a kit with everything you need to put the Z51 brakes on your car for about $600.
Tom
Aug 19, 2007 | 06:28 PM
KenC6
your right Ken, he can upgrade to Z51 with no problems.
Aug 19, 2007 | 08:32 PM
Tom
The only difference is the rotor diameter, so the bracket that holds the caliper must be changed to move it out.
Same calipers and pads, buy the other parts online and do the job yourself in less than 2 hours for all 4 wheels.
Aug 19, 2007 | 11:48 PM
St. Jude Donor '13, '15
Ken02busa
No, just changing the rotors will cost around 900 to 1000 for the eradispeed 2 piece rotors.
Aug 20, 2007 | 09:40 AM
If you want maximum performance, buy the cheapest, solid, undrilled, unslotted rotors. They'll outlast any of that blingbling drilled stuff that just gives cracks a good place to start.
