Mid Engine likely for c7
Old Aug 22, 2007 | 05:03 PM
vette-oholic's Avatar
vette-oholic
Default Mid Engine likely for c7
found this in the blue devil section...
http://forums.corvetteforum.com/show...post1561610835
Old Aug 22, 2007 | 05:36 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Nope! It'll never happen. Too expensive.
Tom
Old Aug 22, 2007 | 06:27 PM
EuroRod's Avatar
EuroRod
Maybe the C12
Old Aug 22, 2007 | 06:29 PM
LS1LT1's Avatar
LS1LT1
Mid engined Corvette, yum.
Old Aug 22, 2007 | 06:38 PM
amped1's Avatar
amped1
The same time they come out with the dual overhead cam engine.
Old Aug 23, 2007 | 10:57 AM
Mike Campbell's Avatar
Mike Campbell
Deja vue all over again. They talked about this in the 80's. Too expensive for one. Cooling & maintainance is another problem. Plus Chevrolet wants to keep the price accessible for an average person to buy. If I'm wrong I'll switch to lite beer.
Old Aug 23, 2007 | 11:21 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
The handling of a mid-engined car is not so forgiving as the current design. The "average Joe" could get into some serious trouble pretty quickly. I don't think you'll ever see it in the "standard" vette.
Old Aug 23, 2007 | 11:38 AM
carpe dm's Avatar
carpe dm
Dave Hill told me they would never do this, in part, for the reasons given above. Of course, he is retired now and the new thinkers may be a bit less conservative... Who would ever guess that GM would consider a $100,000 sports car?????
Old Aug 23, 2007 | 03:41 PM
vette-oholic
you gyts surprise me.
i didnt expect so much closed-mindedness
i believe it will happen.
Old Aug 23, 2007 | 04:01 PM
Silverton's Avatar
Silverton
The two major undisputed advantages are: (1) better traction on accleration, and (2) better braking. A third advantage is improved cornering due to greater traction at the rear wheels, allowing for earlier application of power. The issue that the handling is not as safe at the limit needs to be addressed. Most of the bad handling at the limit (think 911s before the 996 model) is directly traced to improper rear suspension geometry allowing for toe-out during lift throttle. Toe-out induces loss of traction and "over steer." I think that proper rear suspension design (think double A-arm suspension like the C5/C6) would solve that problem.
Race cars since the early 1960's have demonstrated the advantages of rear mid-engine/rear wheel drive. You don't see ANY front engine/real wheel drive purpose-designed race cars. The disadvantages for street cars with rear mid-engine/rear wheel drive are: (1) the car is usually limited to 2-seats only (not a problem for Corvetttes), and (2) more limited luggage space. The limitation on luggage space is, I think, the only real disadvantage for Corvette owners.
Old Aug 23, 2007 | 04:49 PM
xfiremd's Avatar
xfiremd
I do not think the cost would be prohibitive, the Acura NSX only cost 90,000, with out dealer mark ups, I would imagine the corvette would much less to manufacture than the nsx with its hand welded aluminum body.
I know this would has been debated a bit, so no use in speculating.
I picture in my mind an NSX with vette power and price of admission, I would buy it in a heart beat.
Old Aug 23, 2007 | 04:53 PM
Evilways's Avatar
Evilways
NASCAR?
Old Aug 23, 2007 | 07:00 PM
robvuk's Avatar
robvuk
Originally Posted by Evilways
NASCAR?
They're supposed to be simulating real street cars.
Old Aug 25, 2007 | 03:07 PM
Mike Campbell
Deja Vue...."Pontiac Fiero"... I don't think they'll go that way, however, if you think about it....transaxle on the C5/C6.....1963 Pontiac Tempest. What goes around comes around!
Old Aug 25, 2007 | 04:57 PM
EuroRod's Avatar
EuroRod
If GM does go for a 'limited production' mid-motored Corvette, it's just anothe example of GM brass following another companies lead. Do you think that the Camero would be coming if Ford had not re-made the retro Mustang? No. A mid-motored Vette is nothing but GM's answer to the GT500. I'm short on time here, but most of GM's new designe are proceded by either Ford, Chrysler, Nissan, or some other company doing it first. If I ran GM, I'd fire their complete design team, and hire some people with some brains and original design ideas. Not a bunch of copycats!
Old Aug 25, 2007 | 04:59 PM
tscales's Avatar
tscales
St. Jude Donor '07
I don't think it will ever happen.
Has there ever been a generation of Corvette where the rumor wasn't "the next generation will be mid-engined".
It's just not a Corvette if they do.
I'd bet good money the C7 will be front/rear.
Old Aug 25, 2007 | 06:26 PM
AU N EGL's Avatar
AU N EGL
or it could be a limited production of 500 mid engine cars, too qualify for the Prototype P1 class for LeMans starting with the 2010 rules
Old Aug 25, 2007 | 06:32 PM
martinblank's Avatar
martinblank
Default But would you buy one...
Mid-engine, assuming there is not a crazy price jump, just assuming, who here would NOT buy a C-7?
To Mid Engine likely for c7
