center console
Old Aug 27, 2007 | 08:08 AM
VETTAMOUS's Avatar
VETTAMOUS
St. Jude Donor '11-'12, '14
Default center console
im replacing center console, i have removed the two bolts in rear of console. i should just be able to pull console loose, but its not pulling loose on passenger side. afraid to put too much pressure is there any bolts on that side?
Old Aug 27, 2007 | 08:30 AM
lsbrodsky's Avatar
lsbrodsky
Yep, there are some threads in the forum with pictures but in short, you have to lift the e-brake boot and there are two screws in there that have to be removed, as well.
Old Aug 27, 2007 | 08:34 AM
VETTAMOUS's Avatar
VETTAMOUS
thanks i was just out there about to yank the fire outta it!! i just cussed the dog for drinking outta my coffee cup. i read the instructions 5 times it says nothing about those bolts your talking about.
Old Aug 27, 2007 | 10:07 AM
VETTAMOUS's Avatar
VETTAMOUS
alright got console out, got everthing transfered except cigeratte lighter. it seems to be whooping me. i see two tabs on each side and im pressing the fire out of them but they dont seem to be going in to release the lighter, what am i doing wrong?
Old Aug 27, 2007 | 02:46 PM
Silverspeed's Avatar
Silverspeed
St. Jude Donor '13, '15
It's been awhile since ive done mine so I'm really not sure. Maybe try giving it a little twist while pushing the tabs? Also are you sure the tabs don't pull out?
Old Aug 27, 2007 | 09:54 PM
STLBLUES's Avatar
STLBLUES
St. Jude Donor '09
See if you can find instructions on B&M's website. I used the instruction sheet that came with the shifter and it was very detailed with pictures. All of the wiring clips were kind of tricky to get loose.
good luck.
To center console
