Manual Trans Issues
. Now it will not go into reverse at all and it makes a horrible grinding noise when you try....Not to mention now it makes a constant whine in all gears driving down the road unless the clutch is disengaged. I immediatley took it back to the dealer hoping i can get this sorted out before the warranty expires...3 months from now. I have very little confidence in the dealer with these cars and was wondering if anyone has had a similair problem with their car....I think im going to start looking for a trade in though before these problems get worse. From my experience...trans problems are hard to eleminate without relpacing the entire thing.
Of course its possible that the screwup is just something simple like not tightening the linkage - I certainly hope so - but if not I think I'd be leaning on them for a new transmission. That's probably something they'd have to talk to the GM district rep about, but if its been an ongoing problem there's a reasonable chance they'll go with it.
There shouldn't be a problem with the warranty for a problem that is well documented as starting before it runs out.
As far as my experience goes, I have an '05 Z51 and have had no problems at all with the transmission. Of course I'm going to drive home with my fingers crossed tonight!
Good luck!
Seems in most cases the end result was a new transmission...hopfuly i can persuade them to come off one if it is not repaired this time.
After taking it in, they said my gears were blue from excessive heat and excessively worn. They told me my driveshaft (torque tube) was bent, and I actually saw this with my own eyes. How in the hell it was bent by a stock car on stock tires I have no idea. But worst of all, they said they weren't going to cover it because of suspected racing. (I retardly left my helmet in the back of the car)
The car had seen one track day, and about 10 passes. It had not been raced at all for over 3 months when the noise started. Eventually they ended up replacing the driveshaft and gears, and apparently the gear bearings that were causing the hum because that went away.
They told me they would cover the damage this time, but I was black listed for future repairs of the same nature, whatever the hell that means. They also gave me my car back insanely filthy and my driver's side tint damaged.
So I was pissed as hell, and totally disillusioned. The Corvette Experience was ruined for me. Either the service shop is criminal or Chevy designed a car that can bend its driveshaft right of the showroom floor. I barely drove it for a whole year. As far as I am concerned if you can't race it, there is no point in having it. I was very close to selling it.
About a year after the whole ordeal my right front wheel bearing started pulsating. I took it to a different dealer this time, and not only did they fix the bearing under warranty, but they also gave me an '07 rear diff. They actually replaced the rear diff first thinking it was the source of the pulse I experienced on the highway, but I wasn't going to stop them. As a bonus, now I don't have any of that low speed sharp turn grinding I had with my 05 diff.
So now, after more than a year hiatus, I am back on the forums, back in the clubs, and back on the road and track with my 05.
I understand that cars will have issues, they are just too complicated. It's how I was treated, the lack of intelligence and common sense at the service dept, and the way my car was treated that really turned me off from Chevy.
Unfortunately there isn't much of an alternative.
Do you have the Z51? Don't they have an external cooler? Could there be a problem with the cooler and/or lines being clogged?
IMO drag racing can be quite abusive to a car. I'm guessing you do have some idea how the driveshaft was bent...it was likely bent from repeated high RPM launches off the line at the drag strip. Should GM warrant damages caused under these circumstances? I personally don't think so....it would be nice if they did but I understand why they don't. I think you were very fortunate that the dealership covered the damage under the circumstances.
You note leaving your helmet in the car may have tipped-off the dealership you were racing the car (and jeopardizing your warranty by your own actions). I'm sure you would be honest and up-front with the dealership but some people intentionally defraud the dealership just to have repairs made under warranty. This is just stealing and the person committing fraud is a thief.
Anyone that wants to modify and/or race their car should be willing to accept the inherent risks and honest enough to accept the consequences of their own actions....'man-up.'
You mention "...It's how I was treated, the lack of intelligence and common sense at the service dept." It seems to me the service department had enough intelligence and common sense to accurately determine you were racing your car. As to how you were treated....IMO you were treated exceptionally well. The dealership/GM did repair your car under warranty when they truly had no obligation to do so.
this is my question... think its cool to be driving it, or should I wait out the holiday weekend with it in the garage? I dont want to make a potential problem worse.
Thanks for any help at all!!!
