Lowering bolt help
Old Sep 1, 2007 | 05:01 PM
bowmanized's Avatar
bowmanized
Default Lowering bolt help
Do you need to remove the leaf spring to put the bolts in?
So far I unbolt the shock and the upper control arms. Then what?
Do I have to unscrew the lowering bolt?
Old Sep 1, 2007 | 06:53 PM
journeyc6's Avatar
journeyc6
No, you don't need to take the leaf spring.
screw the bolt al the way up, if you want a conservative lowering.
cut some of the rubber or buy a set of lowering bolts if you want more radical lowering.
the shorter the distance betwen the end of the leaf spring and the lower A arm the lower that the car will be.
Old Sep 1, 2007 | 11:59 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
You don't need to unbolt anything - just put a jack under the leaf to take some tension off and use a 10 mm to screw in the adjusters. Back won't go down much unless you cut a couple of layers of rubber off. I tried to do that with a hacksaw, gave up and had my shop pop he ball joint and take out the adjuster and cut it. Front will go quite low without cutting.
Old Sep 2, 2007 | 02:10 AM
bowmanized's Avatar
bowmanized
Yeah it's cool, I already had the bolts in the kit so I just took the leafs off. It was easy.
Thanks for your help
Old Sep 2, 2007 | 07:40 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
No you don't.
To Lowering bolt help
