160 thermostat local store
I suppose it is possible, not probable. Try www.southerncarparts.com or one of the other Forum vendors. http://www.southerncarparts.com/corv...e-c-52_63.html
Don't know about LS3, check the Dealers parts dept for the replacement #, if it's the same as the LS2 then buy from a Vendor. I couldn't find a parts store with a listing for an LS2 160° stat, I ordered my LS2 stat from Tbyrne.
LS2 160° stats are a Vendor protected item. When you buy from a Vendor they ship in their own packaging with the manufactures name and stock # removed. Around $20 for the stat, even though the Manual says a new housing is needed you DO NOT need a new housing. The language in the Manual wasn't up-dated from C5's.
okay, so it seems the ls1, ls2, ls 6, ls3 etc all use the same stat. I got my local forum vendor down a bit. So with shipping, it is basically the same to buy from him even with tax. Even if its a few bucks more, would rather support the local guy that is there to do my installs if needed.
Thanks Guys
Thanks Guys
Thanks Guys
Thanks Guys
Here is where I got mine....recommended by me.
http://cgi.ebay.com/ebaymotors/2004-...QQcmdZViewItem
