I am looking for a cam that won't suffer hot start idle issues. and isn't too lopey. I like the stock idle (or close to it.) I understand the performance/comfort tradeoff on a cam; looking for a good balance. I drive in traffic, although, not my daily driver.
How is the cheaTR cam? Other ideas? I would ike 400RWHP or more ( ) without getting lopey or giving up driving comforts, would like something that makes good torque down low.
The 224/224 .588/.588 cam is a very popular choice for what you want. We also like using and older style "split" cam 228/222 .588/.588 cam as well, and have seen great results with both cams. The split cams are hardly noticable at idle, the 224/224 cam is a little more lopey, but not by much. Both these cams see about 420rwhp on our Mustang dyno with headers and cold air intake.
The other option is a LPE GT11 cam. But the lift is so high on this cam that you really need a set of heads to get everything out of this cam. It sounds almost stock, and with heads we see about a 90-100rwhp gain at the tires.
Thanks for the replys. Mike, do those suffer from hot start issues at all? I don't plan on doing heads at this time. I am jus tlooking cam only? Where do these cams start to produce power? 3k and up?
Jack , How do you like the MTI Staelth II? What kind of power are you seeing and how is the idle?
[QUOTE=stroked250;1561884535]Thanks for the replys. Mike, do those suffer from hot start issues at all? I don't plan on doing heads at this time. I am jus tlooking cam only? Where do these cams start to produce power? 3k and up?
[QUOTE]
I'd have to look back on the dyno sheets, but from my memory the 224/224 and the Split cam both make power from about 3200rpm and up. I have not had any feedback on hot start issues with these cams, so I'm assuming that there's not.
