CODE ERROR P0449 after CAI and CATBACK INSTAL
Old Sep 14, 2007 | 07:38 AM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
Default CODE ERROR P0449 after CAI and CATBACK INSTAL
The other day I installed a VARARAM CAI and then I installed the
BORLA STINGERS W X pipe. Then I noticed the CEL came on. When
I checked it out with the PREDATOR CODES P0449 and P0801 were
present.The 0801 was a reverse inhibit and that explains why I
have difficulty getting into reverse.
I have not changed any programing in the flash and the stock settings are in there.
Does anyone have any idea how to cure these CEL'S ????
Old Sep 14, 2007 | 10:07 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
delete them and see if they'll come back again. I hope other members could help you with this issue if I couldn't!
Old Sep 14, 2007 | 10:47 AM
C6~Missle's Avatar
C6~Missle
Make sure the reverse lockout is still connected on the tranny. It's near the CAGS connector.
You might want to reset the PCM by disconnecting the battery for a couple of minutes...
Old Sep 14, 2007 | 05:19 PM
lemans 07's Avatar
lemans 07
I would make damn sure you didn't let the wire for the reverse lockout touch your pipe and melt
Old Oct 2, 2007 | 03:31 PM
LSCHLEM's Avatar
LSCHLEM
Default CEL condition corrected P0449 code after catback installation
Just received my 07 service manual. What a help. At the time of installation they probably shorted the reverse lockout solenoid hot wire to ground. Thus blowing a 25 amp fuse that feeds the reverse lockout and the canister vent valve. Two presumably unrelated conditions.
All ok now . Now i can get on installing my LG lt Headers.
To CODE ERROR P0449 after CAI and CATBACK INSTAL
