Heavy objects - luggage or a pet - in the C6 back area could be killers in a crash or high speed panic stop. Has anyone found or made a barrier or guard that will pretect that area?
My measurement is 19 inches high by about 30 inches wide.
We are leaving on an extended trip shortly and my wife and dog are expecting a fix - pressure is on!
their are a couple people on the forum that make a divider but not that high. put the dog in a portable kennel and strap it to the net. i think its down south vettes and gene has something from gm
For massive frontal impact -- You've already got two steel-reinforced thickly-padded barriers between your body's vital areas (head, upper torso) and the cargo... namely, the Corvette's seatbacks. I'd think twice about carrying anything around in the back of my car that can get through those. The only thing really exposed is your shoulders; I'm no Doctor, but I would think they're capable of sustaining a pretty good hit without being life-threatening.
If we're talking a roll-over and not just a front impact, thats totally different. You'll need some sort of reinforced net or something that can contain the cargo without totally obscuring your rear view. A simple half-wall partition won't do it.
This partition from ExoticVette would help. It's not a solid barrier but will hold some items back.
A hundred pounds of luggage slamming into the seatback in a 15 g crash is 1,500 pounds of force on the seatback. With the airbag on one side and a suitcase on the other, you're head is really going to ache.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
St. Jude donor in memory of jpee '14
Unless you bolt something very strong between both sides behind the seats (like the metal bar in the Z06) the above referenced quote will happen because the stuff in the back does not have a air bag to slow it down.
A lot of valuable info here which I appreciate - especially the 'headache' physics. Obviously part of the solution needs to be a strong bar between the seat backs. As for the smaller stuff flying I am considering this: http://www.retract-a-gate.com/retrac...-pet-gate.html
mounted to operate vertically and latch at roof.
What do you think?
What do you think?
I am not an engineer ...... but if you are going 65 MPH and you nail the brakes will that gate stop something traveling that fast ..... even if it is very small, I doubt it
My physics are not good enough to know the maximum object weight that can be stopped from 65 mph to zero - quickly - by a curtain that is rated to hold back a static 200 -250 lbs. Hopefully someone else can help with that. - Maybe someone at Bowling Green can express a view of how Chevy views the safety issue here.
I do believe these three things:
A well secured curtain will stop some stuff from flying forward some of the time - and any help improves the chances of less damage.
The closer that objects are placed to the back of he curtain the lower the 'fly time' of loose objects and the less the chance of 'penetration' into the passanger area.
Chevrolet, and most other car companies, should be doing
a much better job of addressing this risk - and educating drivers about the risk. Chevrolet - please note your liability here [hopefully Chevrolet scans the forum for issues to address].
My opinions here are greatly influenced by a family Toyota Sequoia that was totaled on I95 with 5 people aboard and full luggage behind - all held back by a Mercedes kevlar curtain I had thankfully saved from an ML320 we sold. Mercedes has done the world class engineering in this area. I hope GM will step up.
My wife [and chief dog trainer] rides shot gun. You can understand my challange in getting her to see my Vette as the family trip car - she has an Odyssey.
BTW, our labrador Louis is actually a trained guide dog and as such is used to riding at the passenger's feet. Which helps explain why there is no room forward left for luggage.
After much further reearch [thanks for all the input] I got this installed tonight in time for a long weekend triip starting tomorrow. I'll report and post a photo when we return but I can tell you the following:
The crossbeam behind the seats can be drilled at the top for installing screws for this.
The far rear attachment is with two small eyebolts which attach in two holes already provided either side of the latch where the plastic retainer plugs are.
The resulting cargo safety retention will be far more secure than any other option I have seen on the forum - and certainly a big step beyond the flimsy signt screen provided by Chevy.
I am still amazed that Chevy did not consdier the basic physics here. We have a joyful vehicle to enjoy at high speed with excellent safety features - with this one glaring omission. Mercedes provides a kevlar crash screen that Chevy should study and design for the next Vette.
Maybe Chevy didn't anticipate people racing with luggage and a dog in back. Or racing with loose bowling ***** in the back.
Assuming you're not riding like a pimp with your hat on sideways and your head between the seats, I don't think anything will hit you. I don't think anything will penetrate the seats. If you hit something hard enough to launch something at your dash, the damage there will be the least of your worries. If you pack your luggage so that a large object is up against the ledge, nothing is going to move.
