Shifting into 1st Gear.....
Old Sep 17, 2007 | 08:52 PM
St.Char's Avatar
St.Char
Default Shifting into 1st Gear.....
2005/C6/12000,00 miles/6speed...I sometimes experience a hard time shifting into 1st. gear from a complete stop, usually only happens when I'm at a stop light. When this happens...I release the clutch and engaged it again, then it goes into first. Otherwise, it shifts fine. Any thoughts?
Thx.-G
Old Sep 17, 2007 | 08:58 PM
Miaugi's Avatar
Miaugi
Many members here have the same problem. Not sure if there is a fix or not, someone will chime in to shed more light on the subject.
Old Sep 17, 2007 | 09:18 PM
opus1111's Avatar
opus1111
It's a problem w/ '05s up to '08s I think. Not sure if they fixed something for '07, but it's never happened to me in mine. For '08 they ground the gears differently to prevent gears blocking.
Old Sep 17, 2007 | 09:20 PM
Walt White Coupe's Avatar
Walt White Coupe
Common problem. As I come to a stop on level ground I put the trans in 1st and then to neutral. If the car doesn't move you should always go right back into first.
Old Sep 17, 2007 | 10:15 PM
1.8t's Avatar
1.8t
I only go into first gear once I have come to a complete stop. Shifting into first gear while still moving is hell on your first gear syncronizer. That syncronizer is much like reverse in that 1 or 2 mph when shifting into it and it will be ok, but anything more is going to abuse it. My last car was an Evo and its syncros are pretty much crap from the get go. If you tried to go into first while moving, you could potentially grind. I never ground first gear one time when using the method I listed above and my car never had a tranny issue....ever. Not bad considering it was making 100whp more than stock. You will find it is also a lot easier to get into gear doing it this way than shifting into first while still rolling.
Old Sep 17, 2007 | 10:53 PM
St.Char's Avatar
St.Char
Thanks for all the comments...The dealership that I bought the car from also suggested that by releasing the clutch and then re-engaging it, should allow the shift into 1st.
Old Sep 18, 2007 | 12:15 AM
Walt White Coupe
At idle the car will go around 5 to 6 mph in 1st gear. If you shift to 1st at those speeds the syncronizer does nothing.
Old Sep 18, 2007 | 12:22 AM
rustyguns's Avatar
rustyguns
The '08 tranny is completely brand new! Double Metal syncros! oh yeah babay!
To Shifting into 1st Gear.....
