Which Gears?
Old Sep 17, 2007 | 10:46 PM
bunzaroo's Avatar
bunzaroo
Default Which Gears?
I have a black z51 automatic on oder, I plan on doing the usual mods exhaust, headers, intake tune, etc. Is it worth swapping rear end gears on these cars? And if so what is the ideal ratio. I'm not interested in top speed, but occasionaly run the 1/4 mile and like the bottom end torque. Thanks in advance.
Old Sep 17, 2007 | 11:24 PM
johnodrake's Avatar
johnodrake
Moderator
Lots of threads on this. Many, including myself, like the 4.10 ratio.
Old Sep 18, 2007 | 12:13 AM
SoldSyclone's Avatar
SoldSyclone
He said auto...
With those mods 2.73 will be the best all arond combo, they should allow you to finish the 1/4 at the top of 3rd
If you think you may want more put your combo together first and see what mph she runs, dont forget to factor in tire hight
Old Sep 18, 2007 | 11:49 AM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
Do you have an A4 or A6 transmission?
I just installed a 3.15 differential from RPM (along with several other mods) and I really like it so far.
You hear so many people saying that changing gears will give you the best bang for the buck in terms of a noticeable SOTP feel and although I was skeptical at first, I'm now a "believer". It's a great upgrade to the car.
Old Sep 18, 2007 | 12:16 PM
timbo79's Avatar
timbo79
I have an 07 A6.. sent you an email as well, but what was entailed on the RPM swap. I have seen the DTE stuff, but after corresonding with TJ, I am starting to lean towards this..
Any and all details appreciated.. You can PM as well.
Old Sep 18, 2007 | 03:24 PM
drivinfast's Avatar
drivinfast
I thought the 08 automatics had an option on different geared rear ends. If that is true, then which gear set did you select?
You might be happy with what you selected
Old Oct 22, 2020 | 09:43 AM
Todd Goodson's Avatar
Todd Goodson
Navigator
I have found a rear diff with 3.42 gear which came out of a c5 z06. This will fit and work on my regular c5 correct? Thanks
Old Oct 22, 2020 | 11:11 AM
4SUMERZ's Avatar
4SUMERZ
Since this thread is 13 years old, I'm thinking that the OP has decided on his C6 2007 gearing by now.
As far as the C5 question is concerned, it may be best to post in the C5 forum, and not on the C6 forum.
Good Luck
Old Oct 22, 2020 | 02:07 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Yo dude.....you're replying to a message that's 13 years old!
To Which Gears?
