Le Mans Master<br><img src="/forums/images/ranks/5k-6k.gif" border="0">
St. Jude Donor '08-'09
Originally Posted by Brett Hunter
No, I have not used this one. I ran across it since I am looking for a different coupler than I am currently using.
I did find the below quote on their site interesting though, especially since I have noticed that several of the CAI manufacturers have switched to the "hump" style.
"This is a must have for any intercooler that is connected solidly to the body. Engines have a rocking motion and piping must be allowed some free play to avoid damage to the intercooler end tanks. Each pipe should have a minimum of one hump hose per pipe."
This makes good sense. That's probably why GM put the accordian coupler in there to begin with.
I can't find a 4"-3.75" X 4.5"L silicone reducer.
I found a 4"-3.75" X 4"L and am thinking of using a throttle body spacer to make up the missing 1/2".
Has anyone tried this yet?
You can soften them up by heating up a large pot of hot water, not boiling, then with thongs pull them out & dry completely, inside & out.
That was my technique to getting them on.
Though out where you are buddy, a few minutes on the pavement in the sun would work too....
