Crystal Red and Jetstream Blue Accessory Update!
We now have the ability to order the CR and JSB door handles and other accessories listed below. If you'd like to order them you can just go to the site at www.gmpartshouse.com. Click where it says click here to enter part number search. Enter the correct part number starting with box #1 and select Chevrolet make.
These accessories below also qualify for the $50 GCA rebate and I do have some left. For the details on that rebate... see this thread below...
http://forums.corvetteforum.com/show...post1561834314
Here are the numbers are the accessories....
19166216 JSB Door Bezels
19166217 CRM Door Bezels
Bezels 112.70 Per Set.
19166220 JSB Rear License Plate Holder
19166221 CRM Rear License Plate Holder
License Plate Holders 72.45 each.
19166218 – JSB Front License Plate Bracket
19166219 – CRM Front License Plate Bracket
License Plate Brackets – 72.45 each.
19169711 – JSB Z06 Spoiler
19169712 – CRM Z06 Spoiler
Z06 spoilers – 201.25 each.
19169980 – JSB Full Width Racing Spoiler
19169981 – CRM Full Width Racing Spoiler
Note the following about future accessories.
Currently the stock spoilers in their body colors are not available.
Fuel rail covers are not available and I will let you all know when they are.
GM will be making interior trim kits with all of the options for the 08. They will make a carbon fiber, similar to the 06 and 07 kit, Velocity Yellow, JSB, CR and Victory Red at this point.
I will keep you all updated as the rest roll out.
Thanks, Gene.
As others have posted GM has suspended operations picking and delivering parts to GM Dealers and unfortunately it won't end until the strike is over. I did overnight some things yesterday and they didn't all make it so I am not even confident in overnighting things.
A couple of points to mention. When everything resumes the orders will be processed by the day that they were received. So, if you're not ordering something because you want to wait for the strike to be over, now is the time to order.
The longer this continues the longer and more backed up things will be when things get back to normal.
As others have stated as well, we stock a lot but that will get depleted rather quickly without being able to get more stock from GM.
If something is AC Delco we can go to the local AC Delco distributor and try to obtain it so don't be afraid to order something AC Delco.
Also, on accessories.. I have a deal with my local accessory distributor (GM Distributor) and they have millions of dollars of accessories in stock and have the ability to get from other GM accessory distributors so we should be able to survive for a little bit with accessories. The local accessory distributors are not UAW.
So, I urge you to order now so that we can get it processed and in the system to prevent a long delay for you after the strike is over.
If anyone has any questions, problems or concerns please call me.
Thanks, Gene.
Cool thanks!
