Engine Cover Necessary?
Old Sep 26, 2007 | 07:57 PM
  #41
boosted_z06's Avatar
boosted_z06
Originally Posted by saplumr
Let's see....how about we pay 50-80k for a car, start pulling engine covers off then decide the engine bay is too ugly to open the hood to show it off???? I'll pass on that idea..
Well your also not passing on that with the covers ON besides the coils getting cooked causing higher current draw but also cooking the fuel in the fuel rail.
Now add the same for the injectors coils and when engine is turned off engine bay heat soaks and the fuel left in injectors is also cooking and leaving deposits. Heat is trapped under covers and we all know what higher heat does.
Those covers are for the carshow types but for best of the engine is pitch those suckers.
Old Sep 26, 2007 | 08:09 PM
  #42
saplumr's Avatar
saplumr
I think GM knows far more than all of us.
Old Sep 26, 2007 | 08:47 PM
  #43
pTr73's Avatar
pTr73
Originally Posted by Andrew T. Clifton
I have an 06 C6 A6, and dont like the big plastic engine cover hiding the engine. Is it necessary for the engine to run or cool properly?
I am sure its mostly for cosmetic reasons!
Old Sep 26, 2007 | 09:21 PM
  #44
torquetube's Avatar
torquetube
You have got to be kidding me!!
I'm not. Most everything that distinguishes the current small-blocks from most sports car engines -- the low 2V pushrod heads with their characteristically small valve covers, the individual coil packs located near (but not over) the side-fitting plugs, even the front mid-engine location of the motor itself -- is rendered invisible by those covers.
If anything, the covers make the engine look more like a run-of-the-mill top-heavy, complex 4V DOHC V6 -- everything the Corvette V8 isn't. No thanks.
Old Sep 26, 2007 | 10:55 PM
  #45
boosted_z06
Yes that is why they are made to come off with no tools and pop right off.
You see them on F-body or pickups ? NO
