From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
I agree with the last post except for one detail – you don’t want to put your foot to the floor immediately since you’ll just end up spinning and losing time in the crucial first few seconds. If you look at some of Ranger’s posts he says that one of (if not the) worst thing you can do is hammer the pedal immediately.
I’ve got a 3000 stall converter now and even while the car was still stock I’ve found that the best technique is only to go about ¾ full throttle until the car is moving and then slam the peddle. This however does take practice because when you’re at the line and your adrenaline is pumping, the natural inclination is to immediately try and go as fast as you can.
The logic behind this is that although you might not be leaving the line with as much horsepower as you possibly could, that’ll easily be made up by the fact you don’t spend the first 20-100 feet spinning. This theory works both with stock runflats and the MT drag radials I’m running now.
Good luck and let me know if you have any other questions.
You want Traction System OFF. One push of the console button. That setting allows wheel spin without intervention by the computer, but retains the aggressive form of Active Handling to help you if the rear comes loose, in the instant before you lift the throttle for safety sake.
I agree that the throttle should be squeezed as fast as can be done without prompting new wheel spin.
Two methods of launch are:
(1) power braking to 1200-1300. Release brake and simultaneously squeeze the throttle.
(2) "flash the throttle," without power braking, and progressively press the throttle to the floor.
Both ways work, but require calibration. A good course of action is to perfect one method and establish a base-line of achieved 60' and 330'. Then try the other method for a few passes to see if improvement comes.
I just thought of a couple additional things:
If you have an A6 trans, I would recommend running in Sport mode. Although I keep forgetting to get hard numbers to back it up, the car does feel a tad quicker than it does when I leave it in Drive.
I wouldn't recommend that you shift it yourself using the paddles however. I was going to try that one night but found that if you let the car shift on it's own, it consistently went almost to redline and then shifted properly every single time.
torque brake it a little... load the tranny by holding the brake.. and giving it a little gas to get some potential power built up.. take it to like 2500 rpms if you can
IMHO, you do not really need to power brake. I have gotten fairly consistent sub 2 second short times just by getting on the throttle pretty hard right from idle. Very little wheelspin. My car has LG headers, TM removed by CoW, and runs 12.65 times. Runs were on the OEM runflats at 25 lbs.
if you can react to the speed of light then go on green. if you see green you are to slow. go on the last yellow light stage up as back as possible ( in between the staging lights)
Christopher,..where do You go to "race" Your Vette?
ps,..picking up My Vette tomorrow with the new 3.15 HH/D Diff!!
Hey brother,
I saw your awesome ride when I was at LAPD yesterday. Your gonna wear those pirelli's out quick with that power and those new gears!! Sounds like you'll be ready to roll for the weekend!
Hey brother,
Thanks John,..I would've liked to have met You as well!
Sounds like You have an AWESOME Vette with those TT's!!
c u soon!!
I would always use the brakes to stall up the converter at the track...Stall the converter up to desired RPM, (usually as high as I could get it without any power braking in the case of stock tires or the car sliding forward in the case of ET street/drags. Release brake and full throttle immediately on last yellow.
I never had a lot of success with flashing the converter. I always saw slower 60' times.
Bone Stock C6, auto trans with OEM runflats at 25 lbs.
I ran 12.9 seconds in the 1/4 mile. First time ever at a track for me. This was after my second run.Thanks goes to Dennis (fdennis50nj) for his sound advice at the track. It was great talking with you. Leif
nice meeting another new c6 racer. see yea next time. practice makes perfect
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
depending upon your previous driving experience i would either say run in 'all off' mode or 'trac off' mode. it depends upon how you naturally react when she gets loose.
you could try this if you want;
front tire pressure 35 psi (measured when hot),
rear tire pressure 24/25 psi (hot),
1/8 tank of fuel,
engine running temps 180-195 (she'll heat up after the run),
windows up/roof on (prefer transparent top),
pull up to the line,
engage the emergency brake,
press the foot brake fully,
slowly bring up the rpm's until you feel the car lock in place,
continue to slowly bring up the rpm's until the first sign of wheel spin (note rpm's),
return the rpm's to idle,
release the emergency brake (continue holding the foot brake),
bring the rpm's just shy (-200(+/-)) of the noted rpm,
hold the car at that point for just a sec. or two,
release the foot brake and simultaneously, depressing the gas pedal as quickly as possible,
be on the watch out for the rear to come around, if she does, slightly correct and lift just a bit, then get back in it.
most of all, HAVE FUN, don't get too serious or you'll psych yourself out.
I can nail my 08 all the way to the floor immediately without spinning. Maybe HRP is preppred better than some tracks. I can also put my throttle on the floor and it only stalls to 1600 rpm at launch. You can feel the TM working. I'm sure with your loose converter this procedure will not work on radials.
For best et you always want to go full throttle immediately assuming you have the traction to hold.
You have to remember that every car is different. As for me, I put it into "competetive mode". That's 2 button pushes. My tires are 30 fronts, 25 back. Keep in mind, any lower tire pressure & the computer WILL cut power! Then I do a short burnout, in S. Pull up to the line. Lock the brakes with my left foot. Tach it up to about 1200 rpm. When the 3rd amber is fully lit, I let off the left foot & stomp the right. I've tried taching higher, & I burned too much. I tried idle, & bogged. My best time with my 06 A6 was 12.48 @ 114.3 mph on street tires.
