Header wrap pros and cons
Old Oct 11, 2007 | 10:35 AM
nastyC6's Avatar
nastyC6
Default Header wrap pros and cons
Thank you to all the forum members who responded to my post for the value of the underdrive pulley...had it installed with NO problems charging even with my battery in the rear of the car..Now another question...........Opinions on header wrapping....value???.Pros/.Cons??.....Has anyone done it on a C6........All opinions are appreciated...Thanks......NastyC6....... ...BOB
Old Oct 11, 2007 | 11:49 AM
lemans 07's Avatar
lemans 07
If you are going that route, get them coated. Same general effect and alot prettier. Personally, mine are raw stainless and have not had a problem with underhood temps or burning wires, etc.
Old Oct 11, 2007 | 12:45 PM
aTX427
Guest
Posts: n/a
mine are coated, but I am not sure if I would do it again. I have read that if the heat does not disapate, it through the headers, it adds to the combustion temps and promotes detonation.
Old Oct 11, 2007 | 12:48 PM
brad@JBAHEADERS's Avatar
brad@JBAHEADERS
I do not recommend wrapping your headers unless it is a race only application - and I do mean race only as in the car is a trailered race car....have the headers Jet Hot coated or going with a coated option from an aftermarket company's offering is really the best way to go on a street application - we have 2 different coatings we offer on our headers
it actually voids the warranty on our headers as well when people wrap them, some other aftermarket companies might say the same thing
Old Oct 11, 2007 | 03:13 PM
jak112460's Avatar
jak112460
Why is wrapping headers a problem. I would like specifics to stainless.
Old Oct 11, 2007 | 03:38 PM
VET4LES's Avatar
VET4LES
Years ago I put Doug Thorley headers on my motorhome. The warranty was void if the headers were wrapped. I think it had something to do with rust but I'm not sure.
Old Oct 11, 2007 | 03:44 PM
ZPirate's Avatar
ZPirate
2025 C8 of the Year Finalist - Modified
I think you would be better off with a coating such as Jet Hot as someone else said. I thought about getting my Kooks headers coated with Jet Hot 2000, but decided against it since they are stainless steel and there is room around them to let the heat disapate.
WHT's Avatar
WHT
The tape/wrap collects moisture. This, and the heat, can degrade the welds and base stainless. Coating inside and out is better.
Old Oct 11, 2007 | 03:46 PM
lemans 07's Avatar
lemans 07
the headers get red hot and it can actually temper the steel and make it weaker. I have seen guys on jetboats do it and the weight of the collector caused the headers to warp and actually drop a couple inches. Too much heat for the steel.
Old Oct 11, 2007 | 04:11 PM
DSOMC6's Avatar
DSOMC6
Wrap is not good for stainless LT's. Call the mfg and they will tell you.
Ceramic coating
Old Oct 11, 2007 | 06:31 PM
brad@JBAHEADERS
the wrap retains heat in a way that can create excessive heat build up and stress on the primary tubes - ive seen this one as well on street cars - I actually saw a guy bang into a set of primarys with the handle of a socket wrench and the tube actually shattered right in front of him
stick with ceramic coating/jet hot coating
Old Oct 13, 2007 | 08:54 AM
nastyC6's Avatar
nastyC6
Thanks for all the input on the header wrap subject.........after considering all the qualified advice .....i've decided NOT to use the header wrap......Always looking for a few more HP.....NastyC6......BOB
Old Oct 13, 2007 | 09:14 AM
FUBUZ06AMG's Avatar
FUBUZ06AMG
FUBUZ06AMG
it's not the best looking coating, but I am going with Swain-tech Coating . If it's good enough for NASCAR it's good enough for me.
I'm going to Swain-tech both the inside and outside of the pipes.
The entire from the headers back to the cat backs, NOT the catalytic converters.
Les
Old Oct 13, 2007 | 07:57 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I would also advise not wrapping headers. It doesn't last long under high heat. I would advise a good ceramic/aftermarket coating, although there are mixed opinions on coating the inside only versus inside and outside. I don't believe coating the inside would be a problem if you're staying N/A or supercharged, although turbo applications are where I'd personally only coat the outside. I also think highly of Swaintech offerings. I'm a Corvette n00b, but have run ceramic coated headers for nearly five years on a turbocharged Subaru.
San
San
Old Oct 14, 2007 | 07:24 AM
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
imo, wrapping isn't as good as coating, as long as you use a quality coating company (jethot, swaintech, etc.). wrap absorbs moisture, dirt, etc. coating leaves the headers looking good as new even after 20k+ miles.
i had my headers coated but i did use some wrap on the x-pipe and cat-back.
Old Dec 24, 2007 | 03:20 PM
Michael Hunter's Avatar
Michael Hunter
Default wrapping headers
I wouldn't recommend it to any one in any condition. In theory it sounds like it would add H.P. to engine, being the engine bay would be cooler. But, when the headers get hot they retain the heat and it is just like you heat treated them. On my race car they would glow and each time I ran it they went through the heat treatment until they got so brittle they cracked into pieces. Get them coated and that is it!
Old Dec 24, 2007 | 03:29 PM
DSOMC6's Avatar
DSOMC6
San
San
Turbo kits for the C6 require their own (mfg spec) exhaust manifolds. Mine are cast iron.
To Header wrap pros and cons
Old Dec 24, 2007 | 03:51 PM
mte.smiles's Avatar
mte.smiles
You might want to take a look at the Melrose headers. They come jet hot coated, the fit is excellent, and life time warranty as long as you own the car. Some folks argue that they are only mild steel vs. Stainless steel. Mild Steel flexes better and less risky for cracks at the flanges. They keep a nice shine which helps if you're showing your car. Check out their FAQ on their website and decide for yourself. So far, my Melrose headers with long tubes and X-pipe have been performing flawlessly. Good luck. I do agree with the other guys here about not wrapping them. Jet hot coating will solve that for you.
Old Dec 25, 2007 | 10:07 AM
AR Headers's Avatar
AR Headers
Premium Supporting Vendor
We also do not recommend wrapping headers because of the combination of heat and moisture built up within the wrapping. We also aren't a big proponent of ceramic coatings with our 304 S/S systems unless the application has forced induction. Feedback from some highly experienced tuners told us coatings on N/A applications, particularly those with greater than stock camshaft lifts and durations can cause excessive heat to back up into the combustion chamber promoting detonation. With mild steel, coatings are a must for longevity and mild steel simply won't hold the heat in as well as S/S. Therefore coating mild steel isn't nearly as detrimental.
Nick
Old Dec 25, 2007 | 10:40 AM
CHASLS2's Avatar
CHASLS2
St. Jude Donor '13
My none coated AR headers do just fine! And they cool off pretty fast.
