will 08 wheels clear a bbk?
Old Oct 13, 2007 | 10:01 AM
02impactblue's Avatar
02impactblue
Default will 08 wheels clear a bbk?
Does anyone know for sure if the new 2008 c6 polished or split spoke wheels will clear a big brake kit or even the zo6 brakes? Looking at the wheel on the car it appears to have atleast another inch of clearance over the 2005-2007 wheels. The polished wheel has more clearance than the split spoke but both have alot more clearance than the 05-07 5 spoke.
Old Oct 14, 2007 | 12:43 AM
chargedsol's Avatar
chargedsol
Old Oct 15, 2007 | 02:49 PM
SimonStern's Avatar
SimonStern
Originally Posted by chargedsol
Old Oct 15, 2007 | 05:59 PM
nwc6's Avatar
nwc6
I have just a bit over 1-3/32" holding a machinists ruler edge against the lettering on the calipers to the inside edge of the wheel spoke. I have the polished wheels.
Old Nov 11, 2007 | 06:22 AM
User 81424's Avatar
User 81424
What BBK do you have?
Old Nov 11, 2007 | 01:00 PM
C6400hp's Avatar
C6400hp
From: DFW This user does not support or recommend the product or service displayed in the ad to the right
Old Nov 11, 2007 | 02:55 PM
nwc6's Avatar
nwc6
Stock Z51 Brakes/calipers. You should be able to get some numbers from the maker of the kit you are looking at and work off that.
Old Nov 11, 2007 | 04:17 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
I can't figure out why Z51 owners think they have a BBK when they just have larger, drilled rotors. I am new to the Corvette, so please educate me if I am misinformed.
San
Old Nov 11, 2007 | 08:44 PM
nwc6's Avatar
nwc6
San
I don't think I have a BBK, but the original poster was commenting about the new polished wheels appearing to have more clearance than the 05-07 wheels. All I was giving him was the measurements off of my wheels so that he could make a comparison.
Old Nov 12, 2007 | 08:06 PM
Anthony @ LGMotorsports's Avatar
0Anthony @ LGMotorsports
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Can't say for sure, as I have not had one to fit.
StopTech makes one of the largest calipers in the market, they have a wheel fitment guide that you can download, print out, and then fit to your wheel.
Make sure the measurements come out the same as they are labeled on the sheet to verify.
http://www.stoptech.com/tech_info/ch...80-2670-00.pdf
Hope that helps, if you have a question about wheels and brakes. I would be more than happy to help.
Old Nov 12, 2007 | 08:34 PM
saplumr's Avatar
saplumr
I don't think any BBK will clear stock C6 wheels.
Old Aug 29, 2008 | 07:58 AM
C5Dream2004's Avatar
C5Dream2004
Default worth a look
This thread poses a good question - Talking the QX7 wheels
I am to;d an 1/8" spacer is all that is needed to run wilwood"s 14" kit but if you look at the 08 wheels they do appear to have more room that 07 OEM wheels.
Has anyone tried this since this was posted??
Old Aug 29, 2008 | 09:20 AM
ATC399's Avatar
ATC399
San
I can't figure out why you posted
Old Aug 29, 2008 | 09:28 AM
C5Dream2004
I was reading the 1st post - BBK and the 08 QX7 wheel compatibility??
Old Aug 29, 2008 | 12:01 PM
nearwater's Avatar
nearwater
I'd like to know about this as well.
Yes, it does seem to have quite a room behind the spokes.
Dan
To will 08 wheels clear a bbk?
