Lifter Tech
Old Oct 18, 2007 | 02:07 PM
Vetteinplano's Avatar
Vetteinplano
Default Lifter Tech
Anyone every used these to tame a wild cam?
http://www.rhoadslifters.com/Pages/Articles.html
Old Oct 18, 2007 | 02:27 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
I have seen mixed results. It really depends on your oil pressure you run at an idle. For me it's just a crutch.
Old Oct 18, 2007 | 03:56 PM
Vetteinplano
Was it on an LS based engine or Gen 1?
Old Oct 18, 2007 | 05:17 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
The article said that it was a Gen III LS1.
Old Oct 18, 2007 | 05:30 PM
glenB's Avatar
glenB
Gen1 but the principle is the same. They work off oil pressure.
Old Oct 18, 2007 | 06:47 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No, as I just posted, it was a Gen III. It's right in the start of the 4th paragraph of the article.
"...on a 4,000 mile '04 Corvette Gen III small block LS1 engine..."
Old Oct 18, 2007 | 06:53 PM
Vetteinplano
Tom,
My question was back to GlenB. He said that he had seen mixed results. The reason I posted that article was because it was conducted by Rhodes on an 04 Vette engine. I was curious to see if there were any actual Vette owners who had used these to calm down a radical cam.
Old Oct 18, 2007 | 07:55 PM
glass slipper's Avatar
glass slipper
I used them in a pair of 467 big blocks in my boat. It was flat tappets instead of rollers and the cams were 296/306 advertised, 241/252 @.050" on 114 LC installed straight up and the custom Bravo drives I run have a max idle RPM limitation of 900 RPM. I swapped them out for regular hydraulic lifters and noticed no difference. The biggest difference was made with carbs built specifically for my cam/engine combo...I could idle the engines down to 500 RPM (it was hitting hard but stable), blip the throttle and have it return to idle cleanly. Based on my experience, I'd say spend your money on a good tune (essentially what the custom carbs were). In my case, the Rhoads lifters didn't work as advertised...your mileage may vary.
Talking to different tuners before I bought them, a common comment was the noise they make at idle as essentially they turn into a solid lifter at low RPM. I never heard the "noise", but then again it was hard to hear anything with two big blocks cackling at idle through open headers with dry exhaust. Full throttle sounded like the whole NASCAR field driving by...all music to my ears!
Old Oct 18, 2007 | 10:00 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Tom,
Ahhhhhh! Sorry! I got you now. :o
To Lifter Tech
