Differentail brace
Old Oct 18, 2007 | 10:36 PM
Bludog's Avatar
Bludog
Default Differentail brace
I am thinking about getting a differential brace to help with my terrible wheel hop on my 06 Z51. Anyone know the best one to use? How hard is it to install myself?
Old Oct 18, 2007 | 10:48 PM
johnodrake's Avatar
johnodrake
Moderator
Mine is from DTE. I don't have a clue on the difficulty factor, but call DTE and they will steer you right.
Old Oct 18, 2007 | 11:18 PM
runutzzzzz's Avatar
runutzzzzz
Who did your rear end?
Old Oct 18, 2007 | 11:43 PM
m_LeDez's Avatar
m_LeDez
From: Houston, Tx.....'05 Corvette M6 LS3 Magnuson Heartbeat
Check this out....
http://www.cajundude.com/differential.htm
Old Oct 19, 2007 | 12:07 AM
Maui's Avatar
Maui
St. Jude Donor '08
me too
Old Oct 19, 2007 | 06:45 AM
EuroRod's Avatar
EuroRod
The brace has nothing to do with eliminating wheel hop!
Old Oct 19, 2007 | 12:27 PM
Wayne O's Avatar
Wayne O
CF Senior Member
There are many factors that can contribute to the small, high frequency oscillations you feel as wheel hop (power, suspension, tires, road conditions, temperature, et cetera). The DTE strut will help prevent consequential damage if you detonate your differential but IMO it will do nothing to counteract wheel-hop.
Better dampers may help but your best bet might be to go with polyurethane control arm and differential mount bushings to reduce the amount of deflection in the soft stock bushings.
As a side note: I don't do extremely high RPM drops off-the-line but I've certainly done some massive burn-outs. With my slightly modified F55 suspension, I've never experienced any wheel-hop. I suspect the almost instantaneous, variable force resistance of the F55 system mitigates wheel-hop.
Old Oct 19, 2007 | 09:56 PM
Bludog's Avatar
Bludog
I really don't do any massive burnouts on the street, but on the drag strip, even leaving the line @ 1500rpms (2006 Z51 T6) and competition mode on, I get wheel hop. Am I just wasting my time & money on a diff brace, or should I go with the diff brace and the polyeuathane bushings?
Old Oct 19, 2007 | 09:57 PM
Bludog's Avatar
Bludog
So what is your opinion of how to get rid of wheel hop?
Old Oct 19, 2007 | 10:28 PM
CMY SIX's Avatar
CMY SIX
better shocks
Old Oct 19, 2007 | 11:07 PM
Bludog's Avatar
Bludog
any suggestions
Old Oct 19, 2007 | 11:34 PM
St.Char's Avatar
St.Char
Originally Posted by Maui
me too
I have this same set-up. I also have the Corsa Sport exhaust, sometimes my tail pipe, on the passenger side, will rub against the brace, when I adjust it, it vibrates against the frame. Just not much room for the tail pipe on the right side. Anyone have this problem or have suggestions?
Old Oct 20, 2007 | 06:50 AM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
The brace is a great mod (I have one) but won't help to eliminate wheel hop. Not designed to. In my experience of hundreds of drag strip runs C5 and C6 the best thing to eliminate wheel hop is get some drag radials. Stop trying to race on your street tires. The sidewalls are too hard for track use. And drag radials will make your racing so much more fun. Spinning your tires is not fun, nor is having your diff replaced. If you search the archives, you'll find most broken rears are with runflats.
Old Oct 20, 2007 | 11:31 PM
oneblackvette's Avatar
oneblackvette
Change the shocks, set tires presure to 24 psi hot most if not all the hop will go away.
Old Oct 24, 2007 | 12:27 PM
cselz's Avatar
cselz
I have a C5 not a C6. But just as a note I run BFG DR's at the strip and even without a 5K rpm dump, I too get A LOT of wheel hop in 1st gear. So much that I have to let off a little. I'm putting in the DTE Differential and Trans braces not to stop the wheel hop (cuz it won't/not designed to), but to hopefully keep my car from sustaining any expensive damage as a result of the hopping (case brakeages, etc.). Now, I will say I am running at full tire pressure when I'm racing.
Because my car is mostly stock in the back (4:10 gears but nothing hardened/HD), I always say that some wheelspin is your friend. However, wheelhop is not.
I would think (although not an expert) that different shocks and/or harder bushings would help make the problem go away a lot if not altogether. The ride on the street I would assume will be less "comfortable" though.
My 2 cents.
-Chris
Old Oct 24, 2007 | 01:02 PM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I have one as well.
Old Oct 24, 2007 | 01:05 PM
Bludog's Avatar
Bludog
Thanks for the great info. What size BFG DR's do have, and will they fit with my Z51 suspension?
Old Oct 24, 2007 | 01:07 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
I will add that i have my car lowered with cut stock bushings and I don't really get wheel hop much at all. I even tested my posi with street tires the other day with no hop. I dunno if the lowering has anything to do with it?
Old Oct 24, 2007 | 01:25 PM
cselz's Avatar
cselz
315/30-18s. My car is lowered as well, but remember it's a C5, not a C6so I can't say about what fits/doesn't fit for you.
-Chris
To Differentail brace
