Shock !!
Old Oct 19, 2007 | 07:19 PM
mo-shy's Avatar
mo-shy
Default Shock !!
I have C6 with Base suspnsion and Z51 sway bars.
i need for shock make the car more Comfortable.
thx
Old Oct 19, 2007 | 07:34 PM
Modshack's Avatar
Modshack
Koni FSD's would probably be the most comfortable..
I have the same suspension with Bilstein sports, and it's firm but comfortable...
Old Oct 19, 2007 | 08:02 PM
CMY SIX's Avatar
CMY SIX
Default ????
maybe a caddy?
Old Oct 19, 2007 | 09:35 PM
stinky's Avatar
stinky
The Koni FSDs are an excellant shock. They'll made my Z51 feel like a combination of the F55/Z51 setup, car is rock solid and flat in the corners, no to little float. A little pricey but worth it.
Old Oct 19, 2007 | 10:08 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
FSDs and Pfadt poly sways made a difference in the BlueCoupe.
Old Oct 20, 2007 | 05:53 AM
User 81424's Avatar
User 81424
More comfortable than the base shocks? Sounds like you need to go back to the base anti-sway bars.
Old Oct 20, 2007 | 07:37 AM
LS3 Machine's Avatar
LS3 Machine
St. Jude Donor '11
Default Shocks
1. Find someone with a truely stiff suspensioned car. Try a Mitsubishi EVO.
2. Drive that car for 20-30 minutes.
3. Go back to your Vette. It will seem like a Cadillac.
But seriously, Ive heard good things about the Bilstein HD shocks as well. I have the Bilstein Sports, and that would probably be a move in the wrong direction for you. You might want the stock sways. I can't believe how soft my Z51 suspension is, and you are complaining about the stock shocks? Different Strokes I get (pardon the pun).
Old Oct 20, 2007 | 08:20 AM
mo-shy's Avatar
mo-shy
i dont notice any difference in ride Comfortable with Z51 sway bar!
just i need for something make the car more Comfortable when i drive the car on bad street/road .(i main on Partitioning the pitfalls of the road or when i pass on any something Heart on the street)
Old Oct 20, 2007 | 09:19 AM
baf2000_1's Avatar
baf2000_1
Don't laugh, but what is your warm tire preasure? The diff between 35lbs ( rides like a rock ) and 30lbs ( rides like softer springs ) is huge. Especially over sharp bumps. I would not do this for lots of highway travel though.
Old Oct 20, 2007 | 10:17 AM
hayseed51's Avatar
hayseed51
I think OPs complaint was on crappy road surface (seams, patches etc.) where the stock Sachs shocks are at their worst. I agree, nothing worse than that feeling in the pit of your stomach when the car becomes unsettled halfway through a hard turn...
Like Pa Blue Coupe and others, I'm really pretty happy with the FSDs and Pfadt poly bushings. It did pain me to pay what you have to for the Konis, but I console myself with what a great buy the bushings are. Now, just a little further tweaking on the alignment, and I'll be all set.
Old Oct 20, 2007 | 10:53 AM
Wayne O's Avatar
Wayne O
CF Senior Member
Changing dampers might help but to get a softer ride you might IMO want to consider going to non-runflat tires. I wouldn't make the suspension too mushy...you did buy a Corvette.
Old Oct 20, 2007 | 02:04 PM
mo-shy's Avatar
mo-shy
The problem is i ordered new wheels (19/20) with 265/30/19 F,and 325/25/20 R . PS2
i Afraid if the ride come like rock, cause it is now at low speed
so what is your opnion?
Old Oct 21, 2007 | 12:10 PM
mo-shy's Avatar
mo-shy
To Shock !!
