reversing unidirectional tires
joe
The guy that reverses the tires direction is an idiot and should be removed from the gene pool.
X12
Seems that most feel it is ok to reverse the direction of tires now though. It was supposedly a bad idea with older tires, but newer tires can supposely take it.
I don't know the real answer, but I feel you can't go wrong if you do NOT reverse the tires. I don't see a real need to do it anyway. If the car is aligned well, you will get the same amount of mileage out the tires regardless, reversing side to side really should not make a worthwhile difference in tire life.
Rotating back to front might help extend the life of all 4 tires together, but of course on a C6 we cannot do that anyway.
As for "directional" patterns... I'd think it technically would not make a difference on dry pavement, but... do you have a trick to stop the rain???
If so, I'd like to know it!
Don't fool around with rain... one freeway spin out could mean getting flattened by a tractor trailer
... respect thy directional tire pattern. The Best of Corvette for Corvette Enthusiasts
also if the tire maker was thinking that his tire was only going to spin in one direction do you think that he tested it much going the wrong way.
I think reversing the direction of the tires causing the tire to fail is no longer true with modern tires. I have GYF1SC tires on my Z06 and I have switched sides of the car to even out tire wear with no problems at all. If you are wanting to rotate and want to keep the direction correct, you can always take the tires off the wheels and reverse them.
I saw an article where they decided to find out how this would affect motorcycle tires on the track. Of course, it was dry out, and the riders couldn't tell weather the tire was on backwards or not. They could only conclude that the only reason to not run them backwards is if you were going to run in the wet.
Don't think it is a marketing ploy, but reversing directions on DRY pavement is probably not going to make a difference.
The only reason to have tread on a street tire is to channel water out from under the tire.
A Goodyear engineer explained similiar info to me
As said above, the tread is strictly for wet pavement. A directional tire has treads to push water away. If the tire is used backward, you will not know the difference until it rains. I've driven with them on backwards in the rain and it's not impossible but not recommended.
The tire is designed to take loads in BOTH directions. THink about it. The load on a rear tire when you are accelerating is exactly the opposite of the load on the tire when you are braking. If it was only designed to accelerate, they would fall apart on braking. Or the other way around. The only solution is to built the carcass of the tire for BI-DIRECTIONAL use. Which is different from the TREAD being UNI-DIRECTIONAL.
We who track our cars generally wear out the left sides of the tires more quickly because most tracks are run clockwise and therefore have more right hand turns. We can generally get another couple of track days from them by reversing. Unless we're running in the rain, we have no concern about the tread pattern and we usually dispose of the tires before we use them in the rain mounted backwards. Having said that, I have driven home from the track in the rain on tires that were not only almost bald but mounted backwards. Once they're almost bald, they probably don't handle any worse whether they are forward or backward.
So for those who think the gene pool will be better without me for doing this, most of the other track dogs I know will have to go too.
Does it make a difference? Probably. Is it an enormous difference? Not in my experience.
These were PS2s, so perhaps the stock runflats are more of a problem.
