I have read numerous opinions about which gearing is best, 410's, seem to be the answer, but all guys seem to have 6 spds. Does anyone have a stock auto, paddle shift other than Corsa sports and Vararam running 4:10 gears?
I always get the biggest kick out everyone hating the 2.56's and wanting to go to the 3.15's. If someone with an A4 came on and said they wanted to put in 4.82's in their car, they would be laughed off the forum. But that is exactly what the A6 with 3.15's is like, an A4 with 4.82's.
I still think the stock 2.56's are an excellent street gear. It's like an A4 with 3.92's so it's excellent for acceleration, but it's also great in 6th gear for cruising and getting stellar fuel mileage.
I am happy with my A6 the way it is, but will be doing headers, cam and heads.
I have the 2.73 A6 and it's enough right now. In fact, I really like it.
I agree with you on the 3.15. I had a A4 with 3.73 and know what that was like. I looked at the ratio numbers and thought about the traction issues I had with the 3.73 1st-2nd. With sticker tires and a converter it would have been better, but no thanks. It was loads of fun, but traction limited.
Correct so your max trap will be 121-122 at 6500 in 3rd.
Remember the track takes the avg of the last 60 feet to calculate MPH
The only thing I don't know is if the converter is locked up under WOT? If it's locked then the 2.73 is good for 124 at 6500 rpm. If there is a 4% converter slip, this comes down to 119.
For the 2007 A6 has anyone looked into the cost of switching to the GMC 2.73 gears ( 2008 option) without any other changes. I do not know if this can actually be done.
I don't care anything about going to the track but if another stock vette is beside me then I want to have an edge. My goal is from red light to red light.
Just because you have lower gears does not always give you the advantage. For example, from a dig you may spin because of your lower gearing. Or from a roll, you may have to start out in 3rd gear where the other car with stock gears is still in 2nd and has the advantage until his car shifts.
check your dealer, they should be able to install it and I would figure if they do it you retain your factory warranty
