Launching '08 6spd
1.) If you have a 6-speed manual and are relatively good at launching, would you mind sharing your secret?
2.) My prior car to this is a s/c 97 Cobra Mustang that I have a set of ET Streets for -- would these mount up to my C6 axles and how weak is the stock rear-end on the C6? (do I need to beef anything up before going to the track and launching the car?)
Thanks very much for your input. I'm hoping this can be a very informative thread for those of us who are not quite as experienced. With my ET Streets in the Mustang, I also have a line-lock and would always do a 6-8 second burnout and just dump the clutch at 4k and pull ~1.7-1.8 60' times without any trouble...this car may need some learning on my part and I want to be sure I learn as much as possible so I don't break things when trying to launch the car.
Thanks a ton.
First, I believe that the biggest thing that results in TM intrusion is "shocking" the drivetrain. That basically means that if you are on a sticky track, and/or with sticky tires, the clutch does not like to be dumped, it likes to be feathered.
As an amateur, one thing that helped me a lot is the way I stage. When both yellow lights light up, I bring the clutch out to the point where I can just start to feel it engage, but not enough to roll out of the staging lights. This keeps me from banging it too much when I do launch. I think this method also reduces the chance of axle-hop - which I virtually never get on my launches.
Again, keep in mind that I have turned 60' times in the 1.95 range on the factory runflats. I know that is not where the top drivers are - they are likely to get into the mid 1.8s with runflats. So I don't claim to be the best, but I do get good solid runs, and very consistent.
Good luck and let us know what works for you
I recently went to the track with my 08. This is all good advice. If I shocked it off the line, it went into wheel hop. I launched on runflats at about 2K, and gave it as much gas as I could with out really breaking the tires too loose. This car will launch if you find the sweet spot. I ran a bunch of 1.9s, and hit one 1.86, which ended up being my best pass: 11.83 @119.94 MPH!
Good luck,
JB
Fess up...your sweet spot is Jenny P with a shot of Torco!
Thanks again, you guys are awesome.
I know one guy (Glennhl) here who figured he dropped .2 seconds off his 1/4 mile time with the TM "Upshifts" disabled. I just bought a HP Tuner and shut off TM Upshifts myself...going to the track tomorrow to see if it will improve on my recent 12.65 time. Stay "tuned".
Without doing any mods, there is some HP on the table with a tune, as well as the TM.
http://www.youtube.com/watch?v=RmjKNF47ZME
I like the analogy of facing a busy intersection off a side street at a stop sign...you want to get across fast and use the throttle, but avoid lighting them up.
A good driver can snap off fast enough 1-2 and 3-4 speedshifts that powershifting doesn't offer much advantage. Practice the 2-3 shift. It's a biotch on the T-56.
http://www.youtube.com/watch?v=ZmHg095BqvA
