P0121 DTC code
Old Nov 3, 2007 | 05:59 PM
6Speeder's Avatar
6Speeder
Default P0121 DTC code
Anybody seen this one before?
The generic writeup is: "throttle pedal position sensor/switch A circuit range/performance problem".
I've been fighting a low throttle opening surge, been attributing it to my new cam and tuning, but maybe not.
Old Mar 17, 2008 | 09:11 AM
mo-shy's Avatar
mo-shy
hve the same problem with o idea how i can fix it
Old Mar 17, 2008 | 09:28 AM
johnodrake's Avatar
johnodrake
Moderator
If you are still under warranty, have the dealer change the sensor - it is a simple R&R. If not, get the part from Gene Culley at GMPartsHouse.com and do it your self.
Old Mar 17, 2008 | 10:58 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Since you mentioned the cam I'd say it's a tune problem. The P0121 (and P0101 and P0106) codes can pop up due to the airflow and or MAP delta does not fall within range of the table. There are three tables in the Engine Diags/General tab (In HP Tuners), Max airflow VS: RPM and Max airflow delta VS: TPS and Max MAP delta VS: TPS.
To P0121 DTC code
