Hey guys. I'm new here... joined because everyone seemed knowledgeable. I don't have a C6, but I do have an XLR and since they're assembled in the same plant, and share at least the same door handle mechanism, I figured they're might be some similarities and you guys might be able to steer me in the right direction.
I don't know if the function has a name, but when you open the doors in our cars, the window retracts the 1/2" or so before the door opens. My passenger door works fine, retracts when opened, raises when closed. However my drivers door will retract when open, but will not raise when closed. I can hear a relay in the dash (pass side) flutter a time or two when it trys to, but it never rolls up. I can manually roll the window up and it will retract when opened again.
Any ideas or input? Is it simply a relay? Is there a module for this that contains the relay???
