When driving the past couple of days, I notice when I slow to around 65 on the highway, then drop to third and nail it, the car gets weird in the steering. Almost like the front gets light and I get a bit of torque steer like you get with FWD cars. Is this normal or do I have a problem?
1. Weather is getting colder, therefore, less traction from cold tires.
2. With alot of torque on tap, it wouldn't suprise me the Vette gets a little squirly.
3. Alignment, but I doubt this is the problem as you can check for uneven tire wear or you have jerkiness when driving around town.
...or
4. There's a problem with some 2008's front suspension/steering...see, the LS2s are better!
Just kidding of course.
I would continue testing it under the same (controlled) conditions to see if you come up with definitive, repeatable symptoms. Of course please wear your seatbelt while doing this LOL.
...or
seems to do the same thing each time, tends to get light on the front end and does a little torque steer, I don't remember it doing this before. Active handling or traction control is not engaging.
Speaking of that, I would experiment with Traction Control on and off and then Active handling on and off and then all the variations of the two combined and Competitive mode as well?
Also try it at different speeds maybe.
Every time you accelerate any car, there is some weight transfer to the rear tyres, unloading the front tyres. This weight transfer depends on the hard you accelerate, the weigh of the car, the height of the CG (center of gravity) and the wheelbase.
Tuning the suspension of the car, you can change only the speed of this weight transfer: if you choose a stiff setup, the transfer will be fast (the car will feel more responsive), and if you choose a soft setup the transfer will take more time. But with the suspension you cannot change the amount of the weigh transfered.
So, what you are experimenting in your car can be quite normal. I feel the same in my car. If you want to reduce this, you can lower your car. If you want the transitions to be quicker, then stiff your suspension.
I think I forgot to mention, this is a z51 car. I don't remember it doing this when I first bought it. Maybe because it was so much hotter out.
Yeah,
The recent cooler weather makes mine feel like way more power is available.
That settles it. This is the best free HP there is. Since it's getting cold here in Michigan, I'm gonna take mine out and do some WOT's while the free HP lasts!
That makes sense. In colder conditions you have more HP on your right foot, so more weight is transfered when you accelerate, and the front is more unloaded, so you feel a lighter steering.
Just to clarify, this isn't just lighter steering. with my both hands on the wheel, I can feel the front end moving side to side. But there is no play in the steering. It was worse the other day. I think maybe the other day the road was still slightly damp, the more power scenario does make sense, but I expect my car to be fully planted at all times. If its doing this at 85MPH, what happens on a race track??
When the front end gets light, camber changes so it may not track as well...Also the LSD may be hunting for engagement and traction, making slight power shifts from one rear wheel to the other. best advice is avoid this condition. On a race track with a good driver, power application is generally (at least it should be) smoother. I don't think anything is wrong with your car...
Modshack nailed it. In all cases smoothness is the name of the game. This car loves smooth drivers who use the throttle as a rheostat not as an on/off switch!
Yeah! I love the (numerous) posts here about guys who get sideways, break traction, hit the guardrail, do massive unintended powerslides, yada yada and all they did was give it a "little" gas...
The fast line and good car control ALWAYS comes from being smooth with your inputs...
With so much torque and power available, smoothness is the key. In my vette, at the exit of slow corners I can sometimes spend 2-3 seconds on the throttle until flat. You have to be patient with the throttle, if not you will probably get a spin.
