Header Install On Jackstands?
Old Dec 3, 2007 | 07:44 PM
Modshack's Avatar
Modshack
Originally Posted by Nimo
Jackstands are fine - but be sure not to drop the last bolt We looked for 1 hour without results and then re-used an old bolt with a washer.
- Later the same week I found the bolt - it was stuck (and vibrating) in the center of the merge and I had to take the header off to get it out
/Nik
LOL...That's exactly where mine ended up. plucked it out with a magnet..Having the right tools handy is...well, Handy..
Old Dec 3, 2007 | 08:13 PM
KillerVette's Avatar
KillerVette
My header instructions say that one header comes out the top and the other drops out the bottom? is this the case for can both be dropped out the bottom.
Old Dec 4, 2007 | 01:13 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Kooks can be dropped out from the bottom.
Old Dec 4, 2007 | 04:56 PM
KillerVette
no i mean the stock headers (manifolds) do they drop out?
Old Dec 4, 2007 | 05:05 PM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Yes the manifolds drop out the bottom.
Old Dec 4, 2007 | 07:13 PM
LSCHLEM's Avatar
LSCHLEM
St. Jude Donor '08-'09-'10
A header install works really well with a Quick Lift. Total install 3.5 HRS
You need a little room under there to hook up the O2 EXTENSIONS.
Thanks to Ralph all was possible for me. Thanks again, Leon
