How to increase chassis/steering feel?
BJK
Also, I just had a 3/8" tunnel plate installed (mainly to reduce console heat) and was surprised at how noticeable the effect on handling was. It's not earth shattering, but noticeable - especially if you're sensitive to chassis/steering feel. If you're gonna do a bunch of suspension mods, you might as well spend the extra $215 or so to throw on a thicker tunnel plate.
have the tech set both sides the same on each axle, do not allow them to just set the toe "in the green" as they can vary drastically from side to side, have then set it even or close on the rear and the front respectively.
You can run anywere from .2 to 1.2 negative camber on the front per factory, (and way more as others will chime in here) it all depends on your tires, driving style, and how much track time you are going to do.
you could start with say 1.2 neg. on the front, the max factory setting, again set each side the same or close, not one .6 and another 1.1---
the rear I would go with .8 neg. camber or so to start...................
---and keep the caster under 7, more than 6.5, up front, again even each side.
Find a shop that will let you tell them the settings you want, and monitor your tire wear, even if it costs you a couple of $100 alignments to get your settings as YOU like them and tire wear is reasonable/performance good, it is worth it considering the cost of a set of good tires @ $800- 1400
Aggressive street / Light track use
Front
Camber: -.75 to -1.5*
Caster: Max but equal ( winds up about 6.5 to 6.7* )
toe: 1/16", 1/32" out to ZERO ( depends on the tracks corners)
Must be equal on both sides not a range
Rear
Camber: -.75 to -1.0*
toe: 1/32" IN
DIY alignment guild https://www.davidfarmerstuff.com/
Front
Rear
toe: 1/32" IN
The bushings are also likely to allow some toe out-in front and toe-in in rear due to deflection. I have found that zero toe front and rear works pretty well with stock bushings, but I add toe-out in front and toe-in in the rear when I go to poly or solid bushings.
I also think that decreasing Caster from the 8.5* factory setting to 6 or so (equal on both sides is most important) will increase steering feel/responsiveness. Certainly a little toe-out in front will make the car more responsive as well. For a DIYer, just put in a 1/16" total toe-out in front for a nice feel.
-Aaron
I know that .03 corresponds to about 1/33.3 -
I also had the shop torque my bolts at the factory settings, I of course brought the torque wrench/sockets. I then had the alignment checked a week later and settings held good, only slight differences over initial.
Is it not more accurate to set at degrees than inches ?
So it is easer to see 1/32" then .03*
