Brakes
Old Nov 12, 2007 | 03:26 PM
ManaaTone's Avatar
ManaaTone
Default Brakes
So i replaced the front rotors and all brake pads on my 05 z51. I purchased OEM products from the dealer and took it to a private brake shop.
I got the car back and well.......my old brakes held better.
Also eventually im going to shoot myself in the head, the brakes are sooooooooooooooo loud it's almost unbearable. It squeeks on hard and soft stops.
People hear me coming an assume it's a 84 geo metro, then they see a c6 vette pull up, how embarrassing.
Any known brake problems?
Thanks a lot guys!
Old Nov 12, 2007 | 07:11 PM
trinydex's Avatar
trinydex
did you bed the pads?
Old Nov 12, 2007 | 08:33 PM
timd38's Avatar
timd38
Doesn't sound like it.
Old Nov 12, 2007 | 10:36 PM
wratran's Avatar
wratran
what exactly is "bed the pad"? I am about to change pad. Is there a good tip on when installing new pad?
Old Nov 12, 2007 | 10:49 PM
From C6ZO62C8's Avatar
From C6ZO62C8
Thanks a lot guys!
two words
hawk ceramics
no noise or dust, well maybe a little
good stopping power
Old Nov 13, 2007 | 12:22 PM
ManaaTone's Avatar
ManaaTone
what is beding the pads?
Old Nov 13, 2007 | 12:24 PM
Newton06's Avatar
Newton06
Most, if not all pads required a break-in period of light braking followed by cooling in between. Essentially, don't overheat of 'mash' the brakes for a few hundred miles (or heat cycles of you track the car). The can cause glazing and poor brake performance.
Old Nov 13, 2007 | 02:21 PM
trinydex's Avatar
trinydex
http://www.stoptech.com/tech_info/wp...contents.shtml
that is stoptech's white papers on bed in.
it's actually hard braking, with cool down between. you'd likely need to do this on a freeway with no traffic so taht you don't look like a crazy stopping from 80 to 0 10 times in a row.
Old Nov 13, 2007 | 06:12 PM
timd38's Avatar
timd38
Originally Posted by Spearfisher
two words
hawk ceramics
good stopping power
I am sure that people will disagree, but I only use ceramic pads. I have them on the Corvette, Lincoln Ls and I just bought a new Acura and the day after I got it got new ceramic pads and zinc plated rotors.
Old Nov 15, 2007 | 12:35 AM
chiefwilke's Avatar
chiefwilke
I have read that the ceramics don't have the stopping power, I don't personnally, just read it. Do you have to turn the rotors every time you do the brakes, i have around 10,000 miles on the originals?
Old Nov 15, 2007 | 02:36 PM
From C6ZO62C8
they will fade on a track event, I would not use them for that, but so far a stop from 140 to 0 provided no fade for me and stopped very well. no complaints here, would I trust my vette on the Homestead inner track with the pads, no,
but there is a trade off,
1. they are quiet
2. don't give much dust
3. soft on the rotors
as long as you don't do track events I think you'll be ok.
Old Nov 15, 2007 | 03:35 PM
FloydSummerOf68's Avatar
FloydSummerOf68
The hawk pads are very good...that is what I will use when I replace mine.
Old Nov 15, 2007 | 05:19 PM
calemasters's Avatar
calemasters
Did you get the new OEM pads, or new AC/Delco DuraStop pads?
Make sure you have the OEM pads.
Did the tech turn the new rotors on a brake lathe?
To Brakes
