What next?
Nov 14, 2007 | 04:57 PM
Quote:
Originally Posted by
jogar80
On a stock car there may be a charging issue. If you have a cam, you have to raise the idle anyway, so that increase more than makes up for the loss with the UD pulley. My car has one installed and no problems of any kind whatesoever.
good point.
Nov 22, 2007 | 01:33 PM
St. Jude Donor '08
Nov 22, 2007 | 01:59 PM
Joe_G
You should get cutouts.
BAHAHAHAHA!!!
Nov 22, 2007 | 02:53 PM
Are you going for HP #s or speed/feel.
Get a set of 3.73s or 4.10s..Either one will feel like almost 50hp...
Just my 2 cents
Jon
Nov 22, 2007 | 02:57 PM
XCELER8
Just my 2 cents
Jon
Good point to consider - but the downside is the MPG hit.
Nov 22, 2007 | 03:21 PM
This is a stupid question, but what is a stroker?
Nov 22, 2007 | 04:23 PM
Newton06
I had a set of ECS 4.10s and the MPG loss was not that much..as long as you can keep your foot out of it.
Its the biggest bang for the buck..
And you will feel the car really quick. Since your car is an M6 you can run in 6th like your normal 5th.
Jon
Nov 22, 2007 | 04:25 PM
chirocorvette
A stroker motor is an engine that utilizes a different crank to achieve more displacement with the same engine block. An engine fitted with an altered crankshaft that has a larger stroke increases the engine's size without increasing the size of the block.
Not my words...
Jon
