Please Help!!! I downloaded the nav update posted on the forum for 05's and I burned the Iso fie to disc as I was instructed. When I ran the disc it said wrong disc type, then went to the updating screen then I i tried to eject the disc but it would not let me and is now stuck on the update screen. What do I do? Did I fry the nav unit?
I have tried everything to fix the proble0. Disconnecting the fuse, disconnecting the battery, letting the car sit for an hour with the battery unhooked. Now when I turn it on it tries to load the disc, then goes to a backlight blank screen. Is there some type of external master reset or did I fry my deck?
Most computer DVD an CD drives have a tiny hole somewhere in the front for which to stick a paperclip (or equiv) into and mechanically force (gently) the drive to spit out the disc if it wont come out the usual way.
I don't have my car here at work to see, but the nav unit might have the same holes. If it does, I would tilt the screen then pull the fuse to the nav before attempting the paper clip idea. Maybe if you could get the disc out it would return to normal.
